04-02-2008, 09:14 AM | #1 |
Rep 7,594
Drives: '19 M2C
Tire Pressure tooo high - Check it
I decided to check my tire pressure since dealers sometimes forgot to check this when they deliver a car.
I was sitting at 38-39 psi all around. I set the pressure to 36psi all around (stock), and you wouldn't believe the ride difference 2+psi makes on run flats. It's a much smother ride.
www.ReTuneTheDeTune.com
2019 M2 Competition (Sunset Orange) |
04-02-2008, 09:30 AM | #3 |
Rep 905
Note to self. Thanks.
2018 BMW M3 - 12.1 @ 121mph
2014 BMW 335i M-Sport (Sold) 12.4 @ 113mph 2008 BMW 135i (Sold) 12.8 @ 106mph |
04-02-2008, 09:46 AM | #4 |
Rep 7,594
Drives: '19 M2C
Yikes!
The only reason I didn't the first day is my dealership always checks them at delivery time.
04-02-2008, 10:25 AM | #5 |
Rep 5,970
I learned my lesson about this when I bought the GTO. The spec on them is 38/40 but for some reason they jack them up to around 50PIS for shipping. A lot of the cars were sitting on the dealer lots like that, including mine. A few PSI really makes a difference on modern low profile tires.
04-02-2008, 12:01 PM | #8 |
Santa Fe Concorso
103
Rep 2,984
Mine was a couple pounds high also, but I'm running 37 front, 36 rear now.
phaze, 32-33 is too low for low-aspect ratio 18s. Too easy to damage tires or wheels. |
04-02-2008, 12:03 PM | #9 |
Rep 7,594
Drives: '19 M2C
I set all 4 to 36psi.
04-02-2008, 12:33 PM | #11 |
Rep 155
I adjusted mine this past weekend. I did 32psi up front and 36 in back. Was trying to dial out a bit of understeer.
[SIGPIC][/SIGPIC] 135i -- Alpine White -- Coral Red -- ZSP Previous --2004 VW R32-- |
04-02-2008, 02:10 PM | #12 | |
Rep 841
http://www.tirerack.com/tires/tirete....jsp?techid=58 Higher pressures = more grip (within nominal ranges, e.g. <45psi) |
04-02-2008, 02:18 PM | #13 |
formerly izzo/comeback
287
Rep 3,382
i have mine at about 36 in the front and 35 in the rear...
front always needs more.... it has all your weight and the engine too!
BMW CCA # 418268
04-03-2008, 07:17 AM | #15 |
Rep 7,594
Drives: '19 M2C
Is anyone going to switch to Nitrogen in their tires? I want too, but I need to find some in the Chicago area.
04-03-2008, 08:32 AM | #16 |
Rep 3,350
