02-03-2024, 06:09 PM | #1 |
Rep 11
Suspension struts replacement
Has anyone found a reliable replacement for suspension struts of F15, with VDC (electronic control of dampening)?
Arnott, which produces replacement struts essentially deletes the VDC function. Aerosus on the other hand look direct replacement for original oem struts and come at a good price. Has anyone tried them or can give feedback? Also, what other options are out there, which keep the VDC function? |
02-08-2024, 03:57 PM | #2 |
Cattlecar
44
Rep 141
I looked at Arnott and I see the confusing info. The shocks and struts looked to have the solenoids with wiring and not just a resistor but specifications list shows variable damping as "NO". I sent an inquiry via their contact link to get the answer from them.
02-10-2024, 05:01 PM | #3 |
Cattlecar
44
Rep 141
I got an answer and they service the adaptive dampers with conventional dampers and resistors to fool the system to keep warning lamp and messages off.
02-10-2024, 07:52 PM | #4 |
Rep 108
Could you share the product link? I have Vdc and the struts seem to cost like 1k usd a pop. I only drive in comfort anyway and am looking for options
04-11-2024, 01:30 AM | #5 | |
Rep 11
Anyone found any reliable replacement struts? Reviews for Aerosus struts do not seem good and the quality of their struts seems questionable. On the other hand, maybe its one of those occasions that you get what you pay. |
04-18-2024, 03:37 PM | #6 |
Rep 313
I’m in the same boat. 90k miles on my 17 X5D and the suspension is feeling crash y like it isn’t damping well. I also saw the OEM EDC struts are $$$$
What about Bilstein B4 or B6 and an EDC delete module? Since non EDC F15’s used B4’s (or the BMW equivalent) it should provide an OEM ride….wondering like you if anyone has advice.
17 X5D
70 2002 |
04-18-2024, 04:50 PM | #7 |
Rep 5,008
If you delete the EDC def go with the Konis red dampers over the b4. Koni has always been my preferred replacement over the past ~5 BMWs.
kristobias297.50 |
04-18-2024, 07:14 PM | #8 |
Rep 313
How do the red dampers ride? I’m looking for sporty but not super stiff as it’s my wife’s dd. Thanks
17 X5D
70 2002 |
04-18-2024, 08:25 PM | #9 |
Rep 4
My 2015 X5D M sport with 130k kms (80k miles) has been suffering from bouncy ride and am getting the EDC and rear air suspension deleted right now, to be replaced with Bilstein B6 shocks and Eibach Pro springs all 4 corners. The EDC and air suspension can both be coded out (no need for delete modules)
04-19-2024, 12:46 AM | #10 | |
Rep 5,008
Basically better than stock in every metric and no compromises that I could find. For aftermarket stuff, that’s very hard to find. |
kristobias297.50 |
04-19-2024, 09:58 AM | #11 |
who is this noob
40
Rep 194
