02-27-2008, 03:27 PM | #1 |
1er
73
Rep 1,205
Max speed design
Just noticed that the theoretical top speed for the 335 and 135 is exactly 300kmph/186mph which is the exact speed rating of the tires. Given this, I have no idea why there is a speed limiter on the cars set 36 mph lower than this.
Also figured out (using someone else's calculator) the horsepower required to overcome aerodynamic drag at 186mph using a Cd*A of .69 = 87 horsepower. Not sure what else comes into play at those speeds, but seems like we have lots of power left over to hit the rev limiter given enough road. |
02-27-2008, 03:44 PM | #2 | |
Rep 812
2) A 135i or 335i with 300bhp will not reach 186mph in any case - I don't know how you've worked that out as the theoritcal top speed, but you've missed something Edit: Hmmm.. wondering if 186 is a typo on your behalf? |
02-27-2008, 03:49 PM | #3 |
Santa Fe Concorso
103
Rep 2,984
There is a 150mph speed limiter on the 135i becuase BMW AG lawyers say so.
02-27-2008, 03:51 PM | #4 | |
1er
73
Rep 1,205
02-27-2008, 05:17 PM | #7 |
1er
73
Rep 1,205
02-27-2008, 05:27 PM | #8 | ||
form follows function
38
Rep 838
drag force = (1/2)*(air density)*(velocity^2)*(cross sectional area)*(Cd, drag coefficient) where did you find the cross sectional area of a 1 series? you would need to be sure to use wheel torque values divided by wheel radius to get force or drag "power" = the same thing but velocity^3 double check units |
02-27-2008, 05:35 PM | #9 | |
1er
73
Rep 1,205
I wasn't attacking the problem of actual top speed in a 1 series, that would depend on a ton of variables. I'm not sure a 1er can hit redline in 6th with a stock motor, probably depends on conditions. |
02-27-2008, 05:45 PM | #11 |
38
Rep 838
right on, i just knew i had seen the Cd value before but that was all. dont know how else youre going to find the answers youre looking for but good luck.
dont most 6spd cars hit top speed in 5th? ie due to higher torque values from the gearing and 6th is just a gas friendly highway cruiser. not sure but i know my cousin's Z06 does. |
02-27-2008, 06:06 PM | #12 | |
1er
73
Rep 1,205
I'm guessing the 135 with the sport pack produces a lot of drag trying to eliminate lift/generate some downforce so I doubt it will hit 186, but it would be interesting to see what the true top speed is. |
02-27-2008, 06:18 PM | #13 |
1er
73
Rep 1,205
Just looked at a post over at bimmerfest, someone had a 335 w/ flash to 175 and climbing and had to stop due to lack of road, seems plausible a flashed 135 could hit 186 on a good day.
Oh, and get different tires before you try this so you can tell us about it afterwards. |
02-27-2008, 06:23 PM | #14 |
38
Rep 838
C6. and yeah, tall gearing, lots of torque, and high rpm/redline (>7k in an OHV??) allow top speed in 5th. it gets to ~60 in first, IIRC. 6th is just crazy tall
02-27-2008, 06:27 PM | #15 |
1er
73
Rep 1,205
I remember clarkson doing a top speed run in 6th... the whole time. he started from 0 in SIXTH... insane torque.
02-27-2008, 06:27 PM | #16 | |
38
Rep 838
seriously! first time ive ever been genuinely scared in a car. and i have some stupid stupid friends. |
02-27-2008, 07:31 PM | #17 |
Rep 2,626
The fact that the 135i is considerably faster to 140 indicates that it probably actually has lower drag than the 335i
'08 Black Saphire/Black Z4 M Coupe
RIP Gretta: Blue Water/Lemon 135i. Died to save me. -ChuckV |
02-27-2008, 08:06 PM | #18 |
38
Rep 838
02-27-2008, 09:40 PM | #19 |
Rep 109
02-28-2008, 01:46 AM | #20 |
Freude am Fahren
31
Rep 703
Drives: B9 Audi S5 Coupe
That's the way I understood it as well, and if I remember hearing correctly, it also has to do with German Govt. regulations (which is why Mercedes-Benz and other German manufactured cars have the same limiter).
02-28-2008, 02:18 AM | #21 |
Rep 863
With a chip raising the speed limiter and some basic bolt ons, reaching max speed should not be a problem, in Germany. I dunno where you guys are at but here in SoCal, there is no way one could drive that fast. If you didn't get killed by the idiot driver changing lanes into your lane, Highway Patrol and the ghetto bird would get you.
Drive safely guys. "With power comes responsibility" :wink: |
02-28-2008, 02:41 AM | #22 | |
Rep 812
