      02-25-2008, 07:05 PM   #1
NJKSC27
automobile aficionado
111
Drives:
Lowering question for you BMW guys
i have lowered 2 previous cars on springs only and had to equip my Acura with an adjustable Ingalls camber kit. Do you think if the 1er is lowered with springs only a camber kit will be needed? i am talking about a slight drop.
      02-25-2008, 07:09 PM   #2
larryn
Drives: '97 332ti, '21 X5 45e, '16 GT4
Technically, you should match the springs and shocks due to the reduction of travel, but if you're doing something minor, like the H&R sports springs, you should be fine.
      02-25-2008, 07:13 PM   #3
NJKSC27
111
Drives:
yes, i would do the whole setup but i was just thinking H&R or Eibachs. i dont know maybe, i might just spring for spring/shock swap anyway.
thanks larry, i knew you would answer
      02-26-2008, 03:35 AM   #4
hellrotm
Drives: F80
If your going to get springs and shocks, just get a coilover setup. But if you just want springs, get the pro-kit Eibachs, they R&D the pro-kits to work with stock shocks.
      02-26-2008, 09:07 AM   #5
BMWeber
Drives: 08 135i
you don't need coil overs. a nice set of shocks and springs is perfect. and you should never just get springs, the stock shocks are too week not to mention you lose travel with short springs and stock shocks.
now a nice matched set like this wouldn't be a bad idea:
http://www.turnermotorsport.com/html...UCT_ID=31016-4
      02-26-2008, 11:03 AM   #6
1ForAll
1ForAll's Avatar
141
Drives: E92
go with the H&R cupkit for something minor. or you can run H&R sports springs with stock shocks, no problem
"Go with Ray's. His e92 is God." - mashimarho
      02-26-2008, 01:22 PM   #7
MVF4Rrider
PCA, BMWCCA
MVF4Rrider's Avatar
102
Drives: 997S, MV Agusta F4, E46 M3
^^ all depends on what you want the outcome to be, how much adjustibility you desire (control over the outcome), and how much you're willing to loose (I meant to say spend!).
I'll never do springs only again. For what? I've finally decided to do the suspension in stages. I've corresponded a bit with H&R and I think I'll try their front and rear matching ARBs (27mm F and 20mm R) first and evaluate the need for coilovers. If I don't get the feedback and confidence I desire in hard cornering and high speed stability then I'll go with KW coilovers. H&R ARBs are a mount and forget item. No maintenance ever required and they do make a huge difference. I had them on my MINI S and what a dramatic difference they made (as in positive feedback and confidence entering corners).
'08 Carrera S 6MT Guards Red/Black ext leather, Carbon fiber pkg, sport exh, sport chrono +, PASM, Nav, Bose, 19" forged turbos, red tranny tunnel
'07 MV Agusta F4 1000 R 1+1, Corse Red/Silver, RG3 race pipes and factory race ECU
      02-26-2008, 04:39 PM   #8
E82tt6
E82tt6's Avatar
103
Drives: '08 Black Saphire Z4 MC
If you're only going for looks, then that's one story.
If you want handling, you'll need to replaces shocks along with the springs, or you'll be in for a sloppy ride.
'08 Black Saphire/Black Z4 M Coupe
RIP Gretta: Blue Water/Lemon 135i. Died to save me.
-ChuckV
      02-28-2008, 11:12 AM   #9
1ForAll
1ForAll's Avatar
141
Drives: E92
I personally will be going with either KW or Ground Control coilovers
      02-29-2008, 08:32 AM   #10
randomquickness
Drives: 996tt
do you all really think H&R sports or pro kit eibachs paired with the stock shocks would have a bad ride? wouldn't it still help handling rather than hurt it?
      02-29-2008, 08:53 AM   #11
BMW Dreamer
BMW Dreamer's Avatar
72
Drives: Modded 06 TL Manual
Leave it stock, DON'T lower it. I have done this, and sure it looks better and MIGHT handle a little better, but the ride is RIUNED. I WILL NEVER lower a car again. Also when you try to sell it, GOOD LUCK. A VERY small group who want a molelested car. I did it to my 07 Acura TL-S and it was a waste of money. BUT it looked better, (who cares)
      02-29-2008, 09:24 AM   #12
MVF4Rrider
PCA, BMWCCA
MVF4Rrider's Avatar
102
That's BS. My ride improved exponetially with my KW V3 coilovers. You buy a well engineered coilover that has specific valving for both high vs. low frequency bumps and you'll be amazed at how every aspect of driving is improved. I bought mine for the improvement in driving/handling characteristics, not for lowering...that was just an added bonus. I guess my point is you get what you pay for.
But you're right in the money you spent on it is gone...
      02-29-2008, 09:35 AM   #13
BMWeber
Drives: 08 135i
not a big fan of ground control unless your racing. they tend to be nosy ie. rattles and such. great for scca race cars you can get all sorts of custom valved shocks and what not.
      02-29-2008, 06:31 PM   #14
Advevo
Drives: M2 Competition, E30 M3 DTM
i have eibach pro kitt on standard mschocks.
It s perfect handling is very nice.
      03-08-2008, 08:48 PM   #15
Impulse
BMW ONE
Impulse's Avatar
15
Drives: 93 RX-7 R1, 135i
I disagree as well. I have had 3 different cars all on coilovers. If the spring rate is picked carefully it will be a better in comfort and handling. On my RX7 I have coilovers and i replaced every bushing with full spherical metal, that car rides better on the street than either of my roommates E46 M3 or Sti
Poor rides on coilovers come from mismatched spring rates and not properly tuned shocks to spring combo's. Or drivers cranking the stiffness all the way up.
135i - Alpine White - Black Leatherette - 6-Speed - Sport Package - Aluminum trim - 6FL
1addicts
