02-13-2008, 12:26 PM | #1 |
Rep 186
Insights from Rooks Fabulous Training Manual...
Imagine, real data!
Biggest revelations for me: The underbody tray is pretty amazing. Interesting they highlight the brake cooling flow pathway. It's a feature that is irrelevant except on the track or maybe the occasional canyon run so it's cool they think it's important. I wondered about that regenerative braking system. Basically under hard braking it turns off the fuel system, and unleashes the voltage regulator. I guess the alternator is designed for high output in short spurts. However I assume it is still belt-driven all the time so wondering what the savings really is. Interesting that it requires a gel-cell battery. All in all sounds like more marketing than substance or at best a lot of technology for a tiny gain? Suspension diagrams are great, wish they diagrammed the sport suspension since the text suggests there are significant differences.
135i built 2/14/08 SGM w/Black and AL, 6 forward gears
02-13-2008, 12:30 PM | #2 |
No longer moderate
325
Rep 4,401
Nah, I suspect the alternator is probably clutched like the A/C compressor - simple idea really, just needed appropriate battery technology and some software to make it work right. For example, long stints on the freeway may drain the battery enough that the software will need to re-enage the alternator. Just my thoughts, but that's how I'd make that happen.
02-13-2008, 12:36 PM | #3 |
Santa Fe Concorso
103
Rep 2,984
Yeah, and the front swaybar is tubular, man, tubular.
Nice details like this make you appreciate BMW engineering. I was blown away years ago when I learned my '69 911T lugnuts were titainium.
02-13-2008, 12:39 PM | #4 |
Rep 1,015
The last words on the powerplant should go to a clearly overwhelmed Hormazd Sorabjee, editor and publisher of Autocar India: “There is something simply magical about BMW’s in-line six. It has a creamy smoothness that makes velvet feel like sandpaper.” |
02-13-2008, 12:44 PM | #5 | |
Rep 186
02-13-2008, 12:45 PM | #6 |
No longer moderate
325
Rep 4,401
You're absolutely correct, most cars do a constant charge via the alternator - BMW appears to have done a very intelligent approach to it as you have pointed out.
02-13-2008, 01:28 PM | #7 |
Rep 10,176
The biggest things for me are:
- We now know that we do get hydraulic steering racks (not electronically assisted) - We know that the eLSD is real, and unique to the 1 series coupe - Much of the suspension is identical to the e90 (that I already have some mods for, which might fit). - Cones are going to sliiiiide under the car, if I happen to nail any on an autocross run. :smile: Very slick belly. - We confirmed ballast in the rear bumper to bring the car closer to 50-50 weight distribution... It's got to be substantial to make some difference. I doubt they would bother for 20 lbs (since petrol would cause more weight than that). Wonder what the car would handle like with it removed, if you could remove some weight from the front, or gave the front a bit more bite. |
02-13-2008, 01:35 PM | #9 | |
Rep 186
02-20-2008, 02:19 PM | #10 | |
Rep 6,759
Removing that dead weight might remove some of the understeer too.
2018 F80 Santorini 2019 Z4 3.0i 2022 X2 M35i |
02-20-2008, 02:47 PM | #11 |
Rep 10,176
adc, are you positive about the rear weight bias? I saw that at one point, and it was refuted as yet another typo in some documentation.
02-20-2008, 04:28 PM | #12 |
Rep 43
The way a regular alternator works is that it charges only when electrically excited by a voltage regulator. If you totally disconnect the wiring, it will basically free spin and not be a drag on the engine.
What BMW has done is to control the alternator from a computer instead of a on/off switch. But this way it doesn't get its maximum charge all the time, only when the dynamics of the system allow. Their will be no drag on the engine when the engine needs to produce power. Current lead acid batteries don't like to be partially charged in spurts. They will not last if not fully charged. So this new battery we're getting is both necessary and a good thing. It's a better battery. |
02-20-2008, 04:44 PM | #13 | |
Rep 6,759
Weight distribution, front/rear – Manual Transmission 47.7/52.3 % Weight distribution, front/rear – Automatic transmission 47.6/52.4 % Once I read about the trim weight, I immediately connected it with the rear weight bias (and part of the understeer issue). Otherwise, how can you explain rear weight bias when the longer 335i Coupe has a 52/48 weight distribution??? Now contrast this with the 335i reviews which wondered about the (relative) lack of understeer - but perhaps not if you consider the front bias of that car.
02-20-2008, 05:06 PM | #14 |
Acquiring the taste.
Rep 151
02-20-2008, 05:26 PM | #15 | |
Rep 2,495
The question is though, why would BMW stick ballast in the 135 and not in the 335? I am sure that there is a much more complex explanation, but it's a good starting discussion. I read that increasing the size of the rear sway bar could also increase front grip (from BimmerFile.com)- but I am not techie enough to really get it??
Arrived! 2022 X4M Competition, SPY + Black Merino
Gone: 2019 X3M Competition, Toronto Red, Adelaide Grey. |
02-20-2008, 05:51 PM | #16 |
No longer moderate
325
Rep 4,401
It's a typo guys - honest. Look at how much of the engine hangs ahead of the front axle centerline. They added ballast in back to keep it from being a 54/46 weight split. If it was 50/50 they wouldn't have added ballast to make it 48/52,
02-20-2008, 08:32 PM | #19 |
Rep 119
Adding weight in the back increases the tendency oversteer. Adding weight in the front increases stability.
I want 1
02-20-2008, 09:21 PM | #20 | |
Rep 772
02-21-2008, 06:56 AM | #22 |
No longer moderate
325
Rep 4,401
