02-07-2008, 12:42 PM | #3 |
Rep 3,742
It is the positive connection to jump the battery which is located in the trunk. Depending upon the model there is a negative (ground) post on the strut tower.
02-07-2008, 12:44 PM | #4 |
formerly izzo/comeback
287
Rep 3,382
sweet i was close!
good thing to know or i would be jumping it from the trunk!
BMW CCA # 418268
02-07-2008, 12:44 PM | #6 |
Rep 1,288
Suspect it is the positive battery terminal cap. In all of my bimmers so far, the battery is in the trunk of the car but the harness runs up the passenger side. Where it enters the engine bay, there is a positive junction terminal typically in that location.
02-07-2008, 12:48 PM | #8 |
Rep 3,742
02-08-2008, 07:50 AM | #10 |
Rep 1,329
02-08-2008, 10:14 AM | #13 |
Rep 10,176
I've been trying to figure out if some of that plumbing up front by the oil filter housing is going to the auxiliary oil cooler. I suppose it's possible. :iono:
02-08-2008, 10:16 AM | #14 |
No longer moderate
325
Rep 4,401
^ Watch this space for futher details. Larry - had the same thought and took this pic yesterday - it occurred to me that the plumbing to the oil cooler might be near the filter housing and there are substantial hoses coming out of the bottom end of the housing. (Bear in mind, I've been told by BMW that the 135i has an oil cooler and it's stacked behind the coolant radiator).
PS - I was going to open the filter cannister cover before I noticed the tamper tell-tale (the green spot of paint). I was a good boy and didn't dood it. ; -) |
02-08-2008, 10:27 AM | #15 |
Rep 10,176
Bingo! If you look here, you'll see the oil cooler parts for the 335i coupe. Those hoses are the ones that show by the filter housing in the pics above (in the first post)...
They are plumbed slightly differently on the 135i, but that's them. |
02-08-2008, 02:15 PM | #16 |
Santa Fe Concorso
103
Rep 2,984
Larry, you lost me. Please put a pointer arrow on the fitting you are referrencing on Hugo's pic.
02-08-2008, 03:03 PM | #17 |
Rep 10,176
I can't point to something that's not there. Take a look at this pic. I highlighted the pieces missing.
02-08-2008, 03:12 PM | #18 |
Santa Fe Concorso
103
Rep 2,984
Thanks! Now I get it.
And I guess we'll have to "get it" from the dealer if we want an in-fender oil cooler.
02-08-2008, 03:26 PM | #19 |
Rep 10,176
One more damning point. The 335i has two oil filter housings. It's pretty obvious as to what they do, and why they are different. The US 135i has the top one, and the Euro has the bottom one (or a 335i with the external oil cooler)...
The bottom one with the oil fittings on it is listed as having a thermostat, obviously to let oil go to the oil cooler of not. |
02-08-2008, 03:40 PM | #20 |
Santa Fe Concorso
103
Rep 2,984
That is bad news for the US buyer. Larry, what ETK link are you using. I can't seem to pull anything up on the one I use.
02-08-2008, 03:56 PM | #21 |
Rep 10,176
I use Realoem.com
If I go into limp mode, I'll have them add it... If I don't, and they've got enough air going thru to cool things, then my car is lighter than one with the external oil cooler. :smile: |
