BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
      01-15-2009, 05:00 PM   #1
White Shark
Drives: M3 Civic (Non-ZCP)
Q: Differential oil part # (E90 M3 DCT)
Hi All,
Can anyone tell me the right differential oil part # for E90 M3 DCT? I had my 1,200 miles service done on my 2009 DCT, and changed differential oil with 83-22-1-467-993, but wanna make sure it's the right fluid. Also wondering whether 83-22-0-406-941 should have been added...
related articles:
http://www.m3post.com/forums/showthread.php?p=2813831
http://www.m3post.com/forums/showthr...&highlight=dct
Thanks!
      01-15-2009, 08:05 PM   #2
GMWNashville
Drives: 19 G05, 16 F80, 10 E70x5D
theres two oils...one is the castrol oil thats added per the 1200 mile service. then theres another oil which comes in the little green topped liter bottles if your diff makes noise with the new fluid(Which some do and some dont)
      02-14-2009, 09:19 PM   #3
mdernst
mdernst's Avatar
Drives: Tesla Model S
2013 BMW M5  [0.00]
Attached regarding Rear Axle fluids.
Mike
      03-11-2012, 09:26 PM   #4
GregW / Oregon
Commander-In-Chief
2122
Drives: 2023 M2 Coupe, 2020 GLE 450
Updated diff fluid
Mine just started grinding again at 38,800 mi. in right hand parking lot turns. Diff fluid was replaced last 1/11 at 29,600 mi. My 3/9/12 service invoice (5 days before warranty expiration) read, "As per SIB 33 01 02, checked current oil installed in rear differential. At previous diff service, P.N. 83 22 9 407 768 was used. As per SIB, drained diff oil and re-filled with updated par number for M-Lock differential. P.N. 83 22 2 282 583."
Diff is now quiet. Last update to this bulletin appears to be 07/01/11, so they are using a different fluid now.
Greg Lake Oswego, Oregon, USA
2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450
      07-06-2012, 08:02 AM   #5
NRBRNG
NRBRNG's Avatar
Drives: '09 E92, SG & '89 635 CSi
Diff Oil
Just had the car in for its usual (FREE) monthly engine oil change (in track season) and they called to say they would do the diff oil service and spark plugs too. Nice people.
I previously had the grinding and therefore replaced the diff oil back at about 12,000 miles. Car now has 22,000.
As Greg points out, they are now using a different oil part number (83-22-2-282-583) and interestingly changed it without grinding or my asking.
Any other examples out there as I believe he and I both use the same dealer?
DCT. Custom Cantrell MS cage. Fire, SCCA, dedicated track. Diffs-online 3.62, diff cooler, MCS 2-ways, SPL arms, TMS solid SF/Diff bushings, RD sway, DO88 Coolers (DCT, RAD, PS, OIL) Akra catless GT4, BPM tune, Hans Recaro, AP Pro 5000R, Cobalt XR2/4 race pads, BBS E88's, Yoko A005 slicks, RKP GT4 Splitter, GT4 canards, APR GT250 Wing, CFK Hood, Flossman CFK fenders, BW carbon doors, Dinan R toe links, Mini battery.
      07-15-2012, 04:39 PM   #6
windinmyhair
Drives: beamer
How common is the grinding sound? Mine does it as well..
      07-24-2013, 11:18 PM   #7
Imcfarlane5
Australia
Drives: 2013 m3 pure and x5 40d
Oil to top up with during break In period for my new M3
I am 1/2 down int a 600k trip in my new m3 and have noticed that the oil is now below the 1/2 way point and dropping. Does anyone know the grade of oil that I should get just in case I cannot make it back to a major city or the dealer.
Ian
      04-30-2014, 10:52 AM   #8
Kunman
Drives: m3
how were you able to get monthly oil changes?
      05-03-2014, 12:39 AM   #9
BzsBimmer
BzsBimmer's Avatar
3274
Drives: '23 G80 FO M3, M3 & MY Tezzy's
So it the Pentosin DCTF-1 no longer the right fluid to use?
ECS and OReiley's carry it - http://www.oreillyauto.com/site/c/de...&keyword=ffl-4
From Oreilly's
UPC: 4008849173332
FFL4
Color: Amber
BMW DCT Transmission
1 Liter
Detailed Description
Pentosin FFL-4 is the only approved First Fill and Service Fill transmission fluid for the new generation of BMW double clutch gear transmissions (DCT). Pentosin FFL-4 is founded on a fully synthetic base oil technology for safe operation at even the highest thermal load. FFL-4 features a special clutch friction performance which makes it mandatory to be applied solely to the double clutch gear box do not mix with any other gear oils.
Make: BMW Reference Number: 83 22 0 440 214
Make: BMW Reference Number: 83 22 2 147 477
ECS Kit - http://www.ecstuning.com/BMW-E92-M3-...ion/ES2677651/
But I also see that now we're to use the 83222282583 (SAF-XJ + FM Booster)
So which is it?
m3post
