ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Suspension and Braking Chat
  TireRack
      02-24-2023, 09:06 AM   #1
blufc3s
blufc3s's Avatar
12
Drives: 2003 Z4 3.0i
Replaced LCAs on my E85
The rear bushings were noticeably worn out. I decided to replace the lower control arms with ball joints at the same time.
Before doing this I had symptoms of a warped rotor. In changing the LCAs this warped rotor system is gone.
Thought I would pass this along as something to look at if you have similar symptoms
wdb4732.00
      02-27-2023, 10:16 PM   #2
rsutoratosu
Drives: Z4 3.0i
I had this on my mdx. Lower control arm bushing were replaced. Thought it was warped rotors with them studdering during braking
-Roranji
Calichase104.50
      03-24-2023, 11:18 AM   #3
Sergio19
Drives: Z4MR
You might still have rotor run out but now its masked with the new bushings.
Only way to be sure is to check your rotors (bolted to the hub) with a dial indicator.
HBC123.50
      04-08-2023, 11:49 AM   #4
Michael9218
Michael9218's Avatar
595
Drives: 2007 Z4 M Coupe
Vented rotors are pretty stout and unlikely to be warped. “brake shudder” is usually worn bushings.
wdb4732.00
      04-19-2023, 04:48 PM   #5
belcom
belcom's Avatar
Drives: '18 540i, '06 Z4si, '07 Z4MC
Did your car shake only during braking or also at highway speeds intermittently around 110-130km/h without touching the brakes?
zpost
