ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Suspension and Braking Chat
  TireRack
      12-23-2022, 02:34 PM   #1
gutus
Drives: 2006 535i
Questions about spacers
Hello,
I’m planning on running H&R 10mm spacers all around. Suspension will be Bilstein b16 and oem style 224 wheels. From what I’ve read, 10mm spacers are fine, but will I need hub extenders for the fronts?
Thanks
      12-23-2022, 03:39 PM   #2
Steeler
Steeler's Avatar
2429
Drives: Built not Bought 04 Z4 VF
Originally Posted by gutus View Post
Hello,
Thanks
Quality spacers will come with an integral hub extender and longer bolts.
No affiliation. https://www.ecstuning.com/b-h-and-r-...-pair/2075725/
W2A Intercooled Vortech V3Si, custom ducting, Alpha N, 60# Bosch,2.62 pulley, multi port WMI, Severn Tuning(pokeybritches), Tial, magnaflow,SS race muffler, 42 design,3.91LSD, H&R, Hotchkis,ST coils,Konis, Megan camber arms, AKG SS, Nylon mounts, Poly bushings, Carbon interior, CF Aero.APEX
      12-23-2022, 04:25 PM   #3
gutus
Drives: 2006 535i
Thanks!
      12-25-2022, 07:56 AM   #4
wdb
dances with roads
wdb's Avatar
4732
Drives: '07 E86, '02 996, '95 Seven
No bolts included with those, FYI. The ad does specify that bolts are required.
      12-25-2022, 08:09 AM   #5
Steeler
Steeler's Avatar
2429
Thanks, just an example of extended hub.
Have a good day.
      12-26-2022, 08:00 PM   #6
lelandr
Drives: Z4MC, E30M3, E90330i, Z3MC
The H&R spacers are quite good stuff. I have a set on my E30 M3, and have used then for driving around and 300+ track days.
In the meantime, I found these guys, and use their spacers on my M Coupe track car: https://www.42draftdesigns.com/
Especially, with spacers, forget bolts. Go with studs as they make mounting a piece of cake. Bimmerworld has Italian-made studs which are great. You see the 300+ track days on my M3? Those are all on the same Bimmerworld studs. Nary a failure if you follow the installation instructions and torque your wheels properly.
wdb4732.00
Steeler2428.50
zpost
