ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Suspension and Braking Chat
  TireRack
      11-19-2022, 10:27 PM   #1
gutus
Drives: 2006 535i
Blisten B16 install
Hello,
I’m planning on ordering the PSS10 for my Z4MC. Are there other parts I should replace/install at the same time? Adjustable camber plates, control arms, etc?
Thanks in advance!
      11-21-2022, 02:50 PM   #2
86Zed
Get off my lawn
86Zed's Avatar
Drives: 6MT
Given the age of the car I would consider the following items
BMW front strut tower reinforcement plates (PN 51717036781)
BMW rear coil spring shims (PN 33531094518)
Sway Bar End Links (MEY-3160604607HD)
Rogue Rear Shock Mounts & reinforcement plate
https://www.rogueengineering.com/Rog...air_p_270.html
Beyond that it is up to you and the current condition of you car. I also did the control arms, bushings, etc. but mine were TIRED.
Good thread to browse https://www.zpost.com/forums/showthr...ighlight=pss10
wdb4732.00
HBC123.50
      11-21-2022, 04:45 PM   #3
gutus
Drives: 2006 535i
Thanks for that! I noticed you didn’t list camber plates. We’re they not necessary?
      11-21-2022, 05:37 PM   #4
86Zed
Get off my lawn
86Zed's Avatar
Drives: 6MT
I installed Vorshlag camber plates with mine (as with the other forum member's photo). I need the additional camber up front running 18x9 wheels and a track focused alignment.
Now would be the time to add them since you'll be in there and due for a ride height and alignment/corner balance potentially. Ground Control and H&R have solid options depending on your usage as well.
      11-21-2022, 06:44 PM   #5
gutus
Drives: 2006 535i
Cool...thanks for the info. I also plan to run 18x9 rims up front. I try to get everything in advance so I don't have to reinstall things. Thanks for the guidance!
      11-23-2022, 03:31 PM   #6
gutus
Drives: 2006 535i
Do the camber plates replace the oem mounts or do I still need the mounts?
      11-23-2022, 04:20 PM   #7
86Zed
Get off my lawn
86Zed's Avatar
Drives: 6MT
They replace it, I would still run the strut tower reinforcement plate between the tower and the camber plate (fits and does not obscure alignment across)
      11-24-2022, 12:40 AM   #8
gutus
Drives: 2006 535i
Thanks!
      12-07-2022, 02:12 AM   #9
gutus
Drives: 2006 535i
I got my Vorshlag camber plates. They seem pretty solid. With the round plate on the top, are the reinforcement plates still necessary?
      12-07-2022, 07:26 AM   #10
86Zed
Get off my lawn
86Zed's Avatar
Drives: 6MT
The Vorshlag setup is beefier than others. I still installed the reinforcement plates, cheap insurance while you are in there.
      01-12-2023, 11:24 PM   #11
gutus
Drives: 2006 535i
For the rear coilovers, do the perches sit on top or bottom. I have seen them both ways depending on different brands while doing a google image search. For the Bilstein b16s specifically, should they be on top or bottom?
Thanks
      01-13-2023, 11:18 AM   #12
86Zed
Get off my lawn
86Zed's Avatar
Drives: 6MT
It should sit at the top with the rear coil spring shim (rubber insert) nested in the bottom.
Image from another Z4 forum
It may work the other way around but a spanner wrench would be tough to get in there.
      01-13-2023, 11:22 AM   #13
gutus
Drives: 2006 535i
Perfect. Thanks for the photo too. Looks like your car is pretty slammed based on that perch setting
      01-14-2023, 08:45 PM   #14
gutus
Drives: 2006 535i
Installed! Thanks for the guidance
86Zed932.00
zpost
