08-22-2022, 09:54 PM | #1 |
Rep 2,052
oversized wheel bolt
so i figured out today that the wheels my car came with were meant to be used with a 12mm spacer (long story on why that wasn't apparent). the fronts are on without a spacer, but with 40mm bolts.
soooo question: if there's no rubbing or other metal on metal interference, have I done any damage by driving like this? or would it have been an obvious stick-in-the-bicycle-wheel situation? not sure how much clearance i have inside the wheel hub.
Current '21 DG X5MC, '22 X5M50i, '11 E90 M3
Recent Past '12 E92 M3 ZCP, '08 E93 M3, '18 F80 ZCP, '04 E46 M3 I think I have an M3 problem. |
08-23-2022, 05:31 AM | #2 |
mTekMods
2157
Rep 2,909
the bolts just stick out behind the hub. im not sure how much clearance you have but if you dont hear anything its probably ok.
2011 Frozen Black/Fox Red E90 M3 650+WHP
G-Power Supercharged First DCT to Manual Conversion Worldwide KW CS, BBS RI-A, BW Headers, Snow 2.5 |
kolosy1529.50 |
08-23-2022, 02:06 PM | #3 |
Rep 801
There's not much behind the front hubs. In the rears, you can tear up the parking brake pretty easily.
I can't remember if it's possible to tear up the ABS sensor on the E9x, but that *can* be an issue depending on the car and bolt length. You would, of course, know if you'd done this. Net-net, you're fine. Would I swap for stock bolts? Yes. But not for any reason other than that it would bother me.
2011.75 E90 M3 | 2006 GMC Sierra LBZ | 2004 X5 3.0i 6MT | 1995 M3 S50B32 | 1990 325is | 1989 M3 S54B32
Hers: 1996 911 Turbo | 1989 325iX |
08-23-2022, 02:25 PM | #4 | |
Rep 2,052
i'll actually put the spacers back on as the PO bought the current wheels (Apex FL-5) he bought offsets that accounted for the spacers. everything clears without that, but i have it all, might as well use it as intended.
