      08-14-2022, 10:16 PM   #1
archipelagoing
Drives: 2020 Corolla
2001 325Ci... worth it?
Literally just need opinions because I'm torn.
Orient blue metallic ext, black int, automatic (pls don't make fun of me). Pretty stock, no major mods. Zero problems under the hood (for now) and it's pretty much functional. 6 grand, is it worth it?
Edit 08/14: Stupidly forgot to mention, it's 172k miles. I rarely drive though and take the bus to work because screw city driving. For reference, I put <21k miles on my current car in the 3 years I've had it.
      08-14-2022, 10:28 PM   #2
Our03z4
Drives: 2008 BMW Z4 3.0si Coupe,
Not to me it isn't, but how many miles are on it?
      08-14-2022, 10:33 PM   #3
GTS Daddy
#Driver
GTS Daddy's Avatar
429
Drives: '23 G80x
Get it.
2016 Focus RS - ende | 2017 718 Cayman - ende | 2007 911 C4S - ende | 2017 Macan - ende | 2015 Macan Turbo - ende
2023 M3xdrive | 2020 Macan
insta: gtsdaddy
      08-14-2022, 11:29 PM   #4
archipelagoing
My bad, forgot to mention that. It's at 172k right now. The reason why this isn't a dealbreaker right away is due to the fact I rarely drive. I've had a lease for 3 years and put less than 21k miles on it in the time I've had it.
      08-14-2022, 11:30 PM   #5
BzsBimmer
BzsBimmer's Avatar
3814
Drives: '23 G80 FO M3 & '23 G05 X5 M50
Check that subframe, VANOS, cooling system, etc.
it’s a 2001. If you’re wanting it as a collector, meh. If you need alternate transportation, maybe.
How’s the interior? My 03 engine blew so I donated it. I’m over E46 chassis.
      08-14-2022, 11:37 PM   #6
archipelagoing
It would be for alternate transport since I take the bus to work (driving in the city is a huge headache)
Interior is pretty nice. There's a scratch in the driver's side panel, but other than that, nothing.
      08-14-2022, 11:38 PM   #7
dangerus_car
Drives: F30
Only if it's a one or max two owners car.
i would never buy 20 years old car, too much risk as a money pit
      08-15-2022, 12:38 AM   #8
whyzee125
Drives: Dinan stage 2 335i
IMO no. Only way an e46 makes sense is if it's enthusiast owned or bought at wholesale price to bring it up to spec yourself. This is retail price from a used car lot with no service history. You'll be 11k into it in no time at all and you'll still have an auto 325. I'd pass.
jacbo81.50
Mosaud19984785.50
      08-15-2022, 06:28 AM   #9
overcoil
Drives: M235i 6spd
who is selling it ?
      08-15-2022, 03:39 PM   #10
IcewaterPete
IcewaterPete's Avatar
Drives: 2020 F33 M Sport, 2021 M2C 6MT
Why do you want it? If it’s just because it’s a BMW and it’s cheap you need to run away. The front pic looks like it is in rough shape and unless you are a wrencher costs will eat all you are saving riding the bus.
whyzee1252623.50
      08-15-2022, 10:46 PM   #11
1SloeEm3
Drives: E92 M3
No. E46 is the worst car especially for 6 Gs. Expect to do a complete cooling system overhaul, vanos, ccv, secondary air pump, fuel pump, fuel filter, maf sensor, air intake boots. The list goes on.
      08-17-2022, 01:22 PM   #12
Vireboy
Drives: BMW E46, F31
I mean it's a fun car to drive around but really depends on if you're prepared to DIY basically all of the weak spots. Wouldn't recommend for someone not willing to get their hands dirty.
M5Rick90335.50
      07-18-2023, 02:04 PM   #13
lordnikon
lordnikon's Avatar
842
Drives: Break My Wallet
Why a 325; might as well get a 330
      07-18-2023, 05:05 PM   #14
pikkagtr
Go Spurs Go
pikkagtr's Avatar
4123
Drives: '22 GR Z4 Coup '06 Z4M Rdster
E90/E92 make better daily
the N51/N52 are decent minus a few known issues that are easily addressed
find a SULEV model with less than 150k and under 15 yrs old and you'd still have the emissions warranty
Look around, 2008-2012 E90*E92s can be had for under 140k ~$7-$8k
      07-19-2023, 12:04 PM   #15
AmuroRay
No Zaku
AmuroRay's Avatar
3690
Drives: M235i
I don't really know of any E46 problem areas other than the water pump (a 45min job) and subframe? Maybe window regulators.
I agree that the E90 is better in every way though.
Mods: Yes.
Originally Posted by umizoomi View Post
As long 3-pedals are an option, I will exercise my right to suffer the handicap and indignity of slower shifts and reaction times.
      07-24-2023, 11:46 PM   #16
LOW4LYF
LOW4LYF's Avatar
2295
Drives: E92 M3 & F85 X5M
After owning a 330ci & 325i wagon, I would totally disagree.
I drove both vehicles for years without any issues.
      07-25-2023, 04:59 AM   #17
A pock marked front is always bad to see and is a sign of previous owners driving too close. First thing to do is to respray the front bumper and hood tip.
      07-25-2023, 05:55 AM   #18
... but price wise if the car is running well after a thorough test run and starts okay from cold then it's worth the price, offer lower if things like tires, brakes etc seem worn.
      07-25-2023, 11:36 AM   #19
1SloeEm3
Drives: E92 M3
Hearing people say this is why I bought a 330i when I was 16 about 9 years ago. I’m not saying it’s a bad car but it needs a lot of maintenance to be made reliable. Everything is well documented on e46fanatics.
      11-28-2024, 06:22 PM   #20
f30.jd__
Drives: BMW F30 340i
I wish it was manual bro
      11-30-2024, 07:09 AM   #21
pbonsalb
Drives: 18 F90 M5, 99 E36 M3 Turbo
Just a year or so late….
      11-30-2024, 01:30 PM   #22
E36 wire harness
It could always be worse
E36 wire harness's Avatar
751
Drives: E53 X5 6mt, F30 340ix 6mt, E36
Agreed E36 is the same just slightly worse.
Add oil pan gasket, valve cover gasket, oil filter housing gasket, power steering system, suspension, brakes, driveline fluid service to the list. The list goes on.
I bought three now $7,000 BMWs in the past 15 months. The one just showed up but in the other two I put about $5,000 worth of parts into each. Give or take I'm too scared to sit down and add it all up. And 6 months underneath them myself rolling around.
This one you could do that to if it was manual but I don't think it's worth bothering with. It would be 6 months before you got it to decent reliable shape and then it's still an automatic.
