08-06-2022, 02:46 PM | #1 |
Rep 27
Whatīs that part?
I just removed the bottom engine cover to clean oil spills from a leaking oil filter housing.
A rubber part dropped to the floor. I honestly have no idea where it came from or where it could be installed. A year ago i had an indi repaired something on the left axis after an accident. Might be a rubber bearing? But from where? Anyone has seen this part before? |
08-06-2022, 03:03 PM | #2 | |
Rep 2,806
E82 / BMWP Springs / Koni Yellows / M front control arms / Adjustable front endlinks / M rear guide rods / Whiteline Poly RSFB
08-06-2022, 03:24 PM | #3 |
Rep 570
08-06-2022, 04:20 PM | #4 |
Rep 117
For sure that is where it's from...there is a little stud on the frame rail that it slips on to. The first time I pulled the airbox, it stuck to the box until it pulled off that stud, then fell out, and ended up exactly where you found yours.
1and11861.00 |
08-06-2022, 04:32 PM | #5 |
Loves me some MHD!
1861
Rep 1,725
Transmission mount
no, really....... honest.....
1and1
135i - E82.N54 2009 BSM - MHD / xHP / DCI, PR CP & 7.5" Race IC / N55 mid & Borla . . WL RSFI, Koni, Eibach & Dinan CP's, M3 CA's / EBC Red's & Firehawk 500's X1 - E84.N20 2013 MGM - JB4 - The Wife's, now with new turbo & ewg |
08-06-2022, 04:59 PM | #6 |
Rep 27
Awesome. You guys are right.
Itīs position #9. https://www.ecstuning.com/b-genuine-...r/13717539903/ Thanks so much for solving this quiz . |
08-14-2022, 02:04 PM | #7 | |
Rep 7
10-03-2022, 06:24 PM | #8 |
Rep 300
Drives: 2010 128i ZSP 6MT
FWIW, I just replaced mine after it got lost (I'm assuming it fell into the underhood shield below the engine and then rolled out onto the road somewhere). I ended up spraying the bottom of the buffer and the frame rail where it mounts (after cleaning the frame rail) with a bit of 3M tacky spray adhesive to help it stay in place.
Almuliman507.50 |
