ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Suspension and Braking Chat
  TireRack
      01-10-2022, 05:22 PM   #1
sikedsyko
Drives: 2005 Z4
Anyone try ISC Coilovers?
I picked up a set of ISC N1 Race coilovers for my E85 2.5i from Bimmerworld. Got them last week and started installing them yesterday, but the bottom of the front shock body is significantly larger OD than the OEM shocks. (2.1" OD vs 1.9" OD) I have the knuckle opened enough to where the OEM shock slid right out, but these won't go in even with the weight of the car resting on it.
I'm following up with Bimmerworld on the fitment, but wanted to see if anyone else had experience with them. I could always try expanding the knuckle, but really don't want to risk breaking the knuckle or it not clamping on the shock body because its out of round.
      01-11-2022, 06:22 PM   #2
TyzToyz
TyzToyz's Avatar
Drives: 2008 BMW Z4 3.0si
Is it possible you bought coilovers for an "M"?
Tye
      01-13-2022, 11:52 PM   #3
sikedsyko
Drives: 2005 Z4
Well, confirmed with Bimmerworld that these were the right parts and they had verified the fitment. I had to open the knuckle up farther than I would with OEM shocks, but after that they slipped right in and seem to fit fine. No noticeable issues with the knuckle.
Hopefully I can get the car corner balanced and a track alignment soon.
      01-14-2022, 12:17 PM   #4
rsutoratosu
Drives: Z4 3.0i
Post pics.. the M front uses 4 bolt.. different design
-Roranji
      01-14-2022, 12:20 PM   #5
rsutoratosu
Drives: Z4 3.0i
Take pic of coil and ur old suspension side by side.. the bottom portion that goes in.. i used different search and it says compatible also
-Roranji
      01-14-2022, 12:23 PM   #6
rsutoratosu
Drives: Z4 3.0i
also is the model # on the box or anything says B008.T
-Roranji
zpost
