BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Mporium BMW
      11-01-2008, 07:21 PM   #1
py0413
py0413's Avatar
Drives: Slow
Overfilled engine oil@@
Picked up the a black sedan last night and went out to drive a big this afternoon. Found that the oil level is too high and oil leaked out from the engine. I guess I should be going back to visit the service department so soon@@
      11-01-2008, 11:23 PM   #2
skierman64
skierman64's Avatar
Drives: E92M3-E46M3-E46Wagon-E89Z4-E36
1994 325is Race Car  [0.00]
2011 BMW Z4  [0.00]
1998 M3 Coupe  [0.00]
2008 M3 Coupe  [0.00]
Where did the oil leak from, what part of the engine. It's a sealed system therefore any leak is a bad sign.
Invest Wisely...The best mod for your money?? BMWCCA high performance driver's school. The mod that lasts a lifetime and improves the performance of any car you drive[/LEFT]
      11-01-2008, 11:41 PM   #3
py0413
py0413's Avatar
Drives: Slow
it's from the cap where u can add in more oil. Dont know if this is too bad. Was asking a frd who does mechanical works for toyota and he told me this is not too big of problem nothing to worry about. I guess I will have to wait until Monday to figure it out then.
      11-02-2008, 12:01 AM   #4
py0413
py0413's Avatar
Drives: Slow
I forgot to take some pictures at the first place. Instead I cleaned it up and damn it it's not leaking out again@@ but oil level indicator still shows way over the maximum point.
      11-02-2008, 12:17 AM   #5
py0413
py0413's Avatar
Drives: Slow
also i forgot to mention that the m3 i got was used as a demo for 1600kms and I asked the dealership to perform an oil change before making the delivery yesterday.
      11-02-2008, 01:19 AM   #6
MysticBlue
Drives: '20 M5C, '09 M3 DCT Coupe
Wow. I guess they REALLY overfilled it.
      11-02-2008, 01:50 AM   #7
py0413
py0413's Avatar
Drives: Slow
I know man!! The indicator shows the level is on top of the scale with MAX display on the side!!@@
Tmr is Sunday and the service department will be closed. I was planning to go out to enjoy the new ride before heading back to busy Monday@@
Damn it! now I am not sure if I should drive or not.@@
      11-02-2008, 01:03 AM   #8
Singletrack
4th down; 4th quarter? Renegade.
Singletrack's Avatar
Drives: 09 SSII E92 M3; 19 FG M5C
Unless there is oil leaking from the actual engine somewhere, I would ASSume that he spilled oil when adding AND overfilled it.
      11-02-2008, 03:05 AM   #9
Romo
Romo's Avatar
Netherlands
1759
Drives: GR Yaris GT4RS
Indicator is showing; > MAX
The manual says to go directly to the dealer, because the engine can be damaged.
      11-02-2008, 07:53 AM   #10
watrob
watrob's Avatar
Australia
140
Drives: MY2022 X5 M-Sport 45e White
Then don't drive it unless they tell you to bring it in. I had an X5 that was overfilled, I rang the dealer and they came around put a tub down the diff stick and sucked out a couple cup fulls of oil. I know you don't have a dip stick in the M3 but I would contact them first.
MY22 X5 M-Sport 45e White, 22"rims, Red Calipers, Ceramic Pads. Better off saying what it does not have and that's a B&O Audio System, otherwise all option boxes are ticked.
      11-02-2008, 09:15 AM   #11
lucid
lucid's Avatar
Drives: E30 M3; Expedition
There is a possibility they might not have tightened that cap properly. You should of course go to the dealer ASAP.
      11-02-2008, 09:17 AM   #12
positiveions
positiveions's Avatar
Lebanon
961
Drives: 19 Tacoma, 16 Golf wagon
they just wanted to make sure you have enough oil reserve just in case you ran out.
      11-02-2008, 09:30 AM   #13
m3pete
m3pete's Avatar
Drives: 2011 X3 35i
When you cleaned the spilled oil and noticed it came out under the reservoir cap, did you notice if the rubber gasket under the cap was off the cap or loose from the cap? It seem like that is a common problem that the technician just cannot put the cap on correctly. You should check that the cap is on correctly everytime the technician changes your oil.
2011 F25 X3 35i, AW
2008 E90M3 AW, bone stock (Sold)
2002 M Coupe TS, GC S/A coil overs, PF05 pads, Toyo RA1
1998 M3/4 AW sold
      11-02-2008, 10:15 AM   #14
ihyln
Drives: M3post sucks
2008 M3  [0.00]
2002 530i  [0.00]
I added about 1qt + 1/4 and its showing max on mine but no leakage.
      11-02-2008, 11:18 AM   #15
drvai
drvai's Avatar
Drives: E92 M3 AW
Do not drive it and take it tomorrow.
      11-02-2008, 02:31 PM   #16
py0413
py0413's Avatar
Drives: Slow
Yes that was what I found. The rubber ring attached to the cap actually came off when I un-capped it. I put it back into the place it is supposed to be and will run the engine again to see if the leak still happens or not. But Monday morning, I am heading back to the dealership for sure.
      04-01-2009, 03:39 PM   #17
Gemcoska
Sleepy Member, wishing I was on the road.
Gemcoska's Avatar
34
Drives: 2008 BMW M3
so i guess everything was fine with this?
2003 Ducati '996
2008 M3: Sparking Graphite, Red Fox Standard, 19s, Premium pkg, Tech pkg, Premium Enhanced Sound, HD Radio, Heated Front Seats.
      04-01-2009, 04:05 PM   #18
mPlasticDesign
mPlasticDesign's Avatar
684
Drives: BMW 230i Msport w/LSD
Location: Astral Projecting: ∞ 23.516 -122 02.625 0242.101 ĕv'rē-hwâr'
Originally Posted by Laszlo View Post
Dude, any oil leaking out of a sealed engine isn't good, regardless of where it's coming out. Oil pushing it's way out of the cap, on a new M3... doesn't sound good at all. I'd ask for a new car... seriously.
+1 you can seriously damage your engine by overfilling.
right @ MAX is ok, just don't want more than that.
      04-01-2009, 04:47 PM   #19
Big Windy
Big Windy's Avatar
Drives: None
this thread is 5 months old, i think that the OP is gone...
      04-01-2009, 05:00 PM   #20
Gemcoska
Gemcoska's Avatar
34
Drives: 2008 BMW M3
well the reason i ask is that i just brought my car to the dealer today for a top off of 1 quart as requested by the idrive.
After the fill up it read one tick below max. I guess I am one of the lucky ones?
It did however take over an hour for the computer to re-read the level. It just kept showing the clock. I was looking to see if anyone knew how that sensor worked.
2003 Ducati '996
      04-01-2009, 05:19 PM   #21
py0413
py0413's Avatar
Drives: Slow
it was fine after dealership took care of it. I have 14000kms and already had to do the "Add 1L" twice. You mentioned that you brought your car to dealership for that? Did they charge you for that? Because it cost me $18 for 1 L of motor oil when I added it myself.
Must stop eating..............
      04-01-2009, 05:27 PM   #22
URBAN LEGEND
Rocky
URBAN LEGEND's Avatar
Drives: 16 M5, 18 ZL1 1LE, 18 M3
You will blow seals once that engine oil gets hot and expands.
22 Audi RS E-Tron GT
21 Model S Plaid
m3post
