ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Suspension and Braking Chat
  TireRack
      04-11-2021, 08:20 AM   #1
Sergio19
Drives: Z4MR
Z4M front sway bar options
I'm looking to try a milder sway bar setup versus stock. The rear is easy as bars from e46/z4 all fit. The front however is a unique setup from what I understand.
Which of these is most likely to fit a stock Z4M front suspension?
1. Z4 3.0/E46
2. E36 M3
Any other candidates?
      04-11-2021, 08:15 PM   #2
maupineda
Drives: E86 Z4MC
Front E46 bars fit also. The rear in the Z4M was already the best (same as M3 CSL). so the one step further is the front M3 CSL
      04-12-2021, 08:36 AM   #3
kyriian
kyriian's Avatar
884
Drives: 06 Black Sapphire Z4MR
2014 BMW X5  [0.00]
2011 Scion tC  [0.00]
The rear bar is not the same on the M Roadster, only the Coupes run the CSL rear bar
The M roadster runs a 21.5mm rear bar, the coupe runs a 22.5mm rear bar
Part numbers shows also
E85M Rear: 33552282181
E86M Rear: 33552282681
Revolution of our Times
I will return to the track, one day.
      04-12-2021, 09:18 AM   #4
Sergio19
Drives: Z4MR
Are there any smaller diameter than stock front sway bars that fit?
      04-12-2021, 09:22 AM   #5
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
What are you trying to accomplish with a softer front bar ?
street or track ?
      04-12-2021, 09:36 AM   #6
maupineda
Drives: E86 Z4MC
I have a coupe so my statement was applicable to my car. If the OP has a roadster he can upgrade to the coupe’s / CSL’s
      04-12-2021, 09:37 AM   #7
maupineda
Drives: E86 Z4MC
Base E46M3, but is not much smaller.
      04-12-2021, 10:03 AM   #8
Sergio19
Drives: Z4MR
Street for sure. I think the car would ride a lot better on uneven surfaces if it has smaller sway bars.
      04-12-2021, 01:29 PM   #9
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
In my experience sway bars make very limited difference in ride comfort.
They aren't adding anything to spring rates for normal driving.
The only time they really add anything is under cornering load or if one wheel drops into a pot hole.
A softer front bar ;
1. Increases front chassis roll.
2. Increases front grip or traction, while decreasing rear grip or traction.
3. Slows steering response.
4. Increases off-power steering at corner entry.
For ride comfort springs and dampers are the only real solution.
AriuSen776.50
v3.2mc94.00
Steeler2428.50
kaybat125.50
      04-13-2021, 03:02 AM   #10
AriuSen
AriuSen's Avatar
Drives: Z4M Coupe
^^^ this.
And so glad u r back!! As I am lol
Instagram: ariusen26
Youtube: Track vids
v3.2mc94.00
inTgr8r2431.50
      04-13-2021, 11:19 AM   #11
Steeler
Steeler's Avatar
2429
Drives: Built not Bought 04 Z4 VF
Soft springs, big bars give perfect combo of ride and handling.
https://www.scribd.com/doc/157853842...is-Engineering
W2A Intercooled Vortech V3Si, custom ducting, Alpha N, 60# Bosch,2.62 pulley, multi port WMI, Severn Tuning(pokeybritches), Tial, magnaflow,SS race muffler, 42 design,3.91LSD, H&R, Hotchkis,ST coils,Konis, Megan camber arms, AKG SS, Nylon mounts, Poly bushings, Carbon interior, CF Aero.APEX
zpost
