ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Suspension and Braking Chat
  TireRack
      01-16-2021, 11:38 PM   #1
c41250n
c41250n's Avatar
Hong Kong
30
Drives: BMW Z4M Coupe
Strut tower position after coilovers installed
So I’ve just install a set of coilovers at my local shop, its my first time seeing that there is play/adjustment on the tower where the coilovers connects to the frame.
attached is the photos of my strut tower, but is this normal?
      01-17-2021, 12:09 AM   #2
ZeD4Mr
ZeD4Mr's Avatar
Drives: Skyer Z4MR
yes, it's normal.. do you know the camber/caster spec?
FB Group-- > fb.com/groups/z4group
Instagram --> @Skyermotorsport
FB Page-- > fb.com/Skyermotorsport
      01-17-2021, 12:33 AM   #3
c41250n
c41250n's Avatar
Hong Kong
30
It’s currently -2.5 camber in the front, but now the left and the right is not the same.
so they use this to help adjust camber with this? or this actually adjust caster?
I’m thinking of adding a strut bar, so it will affect the camber?
      01-17-2021, 06:33 AM   #4
Michael9218
Michael9218's Avatar
595
Drives: 2007 Z4 M Coupe
Those slotted holes allow small adjustments to camber. Some strut bars also allow for this adjustment (OEM and Strong Strut do for sure).
      01-17-2021, 09:55 AM   #5
GuidoK
#buildnotbought
GuidoK's Avatar
10855
Drives: Z4 3.0i ESS TS2+
I don't think the slots are that much elongated? (maybe the m coupe is different?)
Maybe the shop altered the holes a little?
I also see a potential crack at one of the holes.
      01-18-2021, 04:58 AM   #6
c41250n
c41250n's Avatar
Hong Kong
30
Luckily I’ve purchased an OEM strut bar.
      01-18-2021, 05:00 AM   #7
c41250n
c41250n's Avatar
Hong Kong
30
I don’t think the shop made the hole bigger and if they have they would have told me, cause i’ll be super pissed.
That’s not a crack, its a scratch with a bit rust on it after the paint is gone..
      01-18-2021, 08:31 AM   #8
c41250n
c41250n's Avatar
Hong Kong
30
I have another question , do you need to use their specific nuts for installing the strut bar?
zpost
