ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Wheels and Tires
  TireRack
      09-17-2008, 03:22 PM   #1
Incompatible
Drives: 07 AW Z4C 3.0Si
TPMS Valve Stem Caps
I've got an 07 with the TPMS units in the valve stems. I've heard that it is necessary to use the oem caps or the sending units will not function properly. Fact or Fiction? I'm at work so I can't pull a cap and check. TIA
      09-18-2008, 02:13 PM   #2
jmillet
jmillet's Avatar
64
Drives: 2023 Hyundai IONIQ 6 SEL AWD
Thumbs down FICTION
FICTION!! The OE cap is made of plastic rather than metal to address corrosion issues of earlier metal caps.
Also the BMW Corporate lawyers wanted to warn you that there is a tire pressure monitor inside and you must reset your TPM. This novella will not fit on the face of a metal cap .
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red
SOLD: 2007 BMW Z4 M Coupe Imola Red
      09-18-2008, 02:19 PM   #3
Hawkeye
Hawkeye's Avatar
Drives: '07 Z4 Coupe, '21 X3, '16 GMC
False because of what was said above. If you get metal caps they easily corrode and become uber hard to get off. Any plastic caps will work though
2007 Z4 3.0si Coupe • 6 MT • Black Saphire Metallic • PP • SP
2016 GMC Sierra SLT Z71 Premium Plus 4x4
2017 Harley StreetGlide • Denim Black • V&H Tune
2021 BMW x30i • Phytonic Blue Metallic • Fully loaded
      09-18-2008, 08:24 PM   #4
Incompatible
Thanks all for the info. Now I'm looking for some silver color plastic caps.
zpost
