01-20-2020, 02:21 PM | #1 |
Rep 872
FS: ESS X-pipe & axle back exhaust
SOLD!
Selling my ESS x-pipe and exhaust. Setup worked great until one of my cats failed late last summer. Willing to throw in the down pipes for free if you want them. One is fine while the other one is toast and will require a rebuild. RRT attempted to push out the damaged cat but it's wedged in right about where the second O2 sensor is located. You can see the dent in the picture. No idea what caused it. Asking $500 OBO for the x-pipe and the exhaust. I've had for 5 years and about 30,000 miles. Saw maybe a dozen track days. X-pipe is heat wrapped because I destroyed my heat shield when installing my 1-piece driveshaft.
AA Gen 2 Lvl 2 w/Meth; MagnaFlow catless x-pipe; Dinan Underdrive Pulley; VAC Coated Bearings; ARP Rod Bolts; Oil Diverter Valve; Dinan Strut Braces; Dinan Rear Toe Links; ECS Rear Trailing Arms; MCS 2-Way NR w/700F-1000R; GC Camber Plates; AKG 75D MM & 95A TM; CAE Shifter; Titan T-S5; StopTech ST60 380mm/ST40 355mm; MFactory DS; Zebulon Splitter; Zebulon 330 Rear Wing; Gutted w/Piper Motorsports Custom Cage; OMP WRC-R Seats
01-22-2020, 04:39 PM | #3 |
Rep 872
