ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Suspension and Braking Chat
  TireRack
      10-20-2019, 01:15 PM   #1
dre99gsx
Drives: 1994 Toyota Supra
Measuring downforce using headlight level sensor
Has anyone tried doing this? I know we can monitor realtime voltage of front and rear leveling sensors using INPA.
I assume you can place various weights in trunk and engine bay to calibrate voltage to weight, then hit the road at 60mph, 100mph, and measure average voltage of those sensors.
      10-22-2019, 07:51 AM   #2
racerbruce
racerbruce's Avatar
3854
Drives: 21 X3 & 13 335is E93
Great question -
Wowie - haven't heard this potential measuring process before; hopeful this will be answered.
Racerbruce
      10-07-2022, 12:16 AM   #3
E86Z4MC
Drives: Z4M Coupe
Any insight into feasibility of this in general? Certainly sounds interesting
      10-07-2022, 11:42 AM   #4
XMetal
XMetal's Avatar
Drives: Anything
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Unless you have super smooth surfaces on your test runs AND you're able to maintain the same line on every run, I don't see how you would obtain anything useful data. The minute surface imperfections would throw off all your readings.
      10-08-2022, 08:54 AM   #5
wdb
dances with roads
wdb's Avatar
4732
Drives: '07 E86, '02 996, '95 Seven
You'd get a less than smooth readout, but the general trends should still be discernible. I like the idea a lot. Clever.
      10-08-2022, 10:03 AM   #6
Vanne
Down Under!!
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
i concur , the trend line would give some usefull info over a longer section of road, however, ive never hear of anyone measuring downforce in this way. Let us know if that works out, Iam writing some code for an Adrino R3 based active aero servo setup, pretty simple to hook one of those up with a high torque servo connected to your wing. I am 1/3 into this as a project myself.
2007 EuroSpec Z4///MC - Building/Developing Z4 GT3
Powered by
zpost
