ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Suspension and Braking Chat
  TireRack
      10-19-2019, 11:12 AM   #1
dptmachine
Life, Liberty and the Pursuit of Motion
dptmachine's Avatar
Drives: 2007 BMW Z4 M3 Coupe
Flossman Wide Body Show Car revision to HPDE car
I have a new car with 151 miles on it with a near full Flossman Carbon Fiber Wide body kit. It was a show/sponsor car in a previous life. I have the task now to figure out about getting this thing going. This is my 1st attempt to organize myself for "phase 1"; getting rolling. Canepa had heated the stock springs on the KW's listed to get a 3-4" ground clearance. Your review(s) are welcome.
**Check my Album
Get the car rolling
1. Dampers
a. Option 1; current Dampers on car. KW 200 1018 ( Art. Nr. 353 20 323) front BDL 330, KW 200 1111 (Art. Nr. 353 20 501) rear BDL333. I cannot find info on these???
i. Can the current suspension be used with new springs and/or other components
1. Supporting components; ARB bars, camber plates, reinforcement plates towers ARB base reinforcement
a. 3M™ Scotch-Weld™ Epoxy Adhesive DP420
b. Option 2; currently owned dampers with MCS 2 way non remote coil-overs for track E46 M3; Eibach 5” 2.25 ID 700#, Eibach 6” 2.25 ID 350#
i. Iteration 1; apply rears, reinforce rear shock tower mounts and source new damper for current control arms
ii. Iteration 2; apply rears, reinforce rear shock tower mounts and front and use SLR control arms
iii. Iteration 3; apply rears, reinforce rear shock tower mounts and AR Motorsports recommendations?
iv. Supporting components; ARB bars, camber plates, Clevis mounts, reinforcement plates towers
1. ARB base reinforcement
c. Option 3; Source entire new MCS kit or like product
i. Iteration 1; non coil-over, no rear shock tower reinforcement
ii. Iteration 2; coil-over, rear shock tower reinforcement
iii. Iteration 3; AR Motorsport other recommendations
1. Supporting components; ARB bars, camber plates, Clevis mounts, reinforcement plates towers ARB base reinforcement
d. Upgraded bushing/balljoints/arms??? What components must be considered with new Dampers
i. AKG 75D Differential bushing set
ii. Vorshlag Motorsports Nylon Competition Engine/Trans Mount set
iii. Ground Control Front Control Arm Bushing set
iv. Ground Control Rear Trailing Arm Bearing
v. Ground Control lower control arm (Race)
vi. Ground Control Front Camber Plate set
vii. Hypercoil zero rate Tender Spring pair
viii. Eibach spring spacer
ix. Replace stock ball joints in rear?
e. Summary
i. When considering my path, w/in reason, I want the cars components to be purposeful and well matched. If the spacers and wheel/tire size for the wheel opening is poorly matched, I am interested in addressing that. Bigger is not always better, but best choice should be considered. Phasing in components from one season to the other is acceptable and considerate to the pocket book.
ii. It would be nice to drive this to track sometimes, cars and coffee maybe, but very little. This will not be a commuter.
2. Wheels
a. Option 1; current wheels BBS 16 0288124, 16 0288123, 14 0288124, 0288123
i. Iteration 1; maintain front wheel spacers. These are not hub centric and measure a “whopping” 26.83 mm with digital caliper
ii. Iteration 2; delete front wheel spacer with custom length control arms
1. Control arm selection may change front damper selection
b. Option 2; change front wheel/tire size
i. Iteration 1; current control arm wheel and tire fitment
ii. Iteration 2; custom length control arm wheel and tire fitment; ie SLR kit that has dust caps and boot
3. Exhaust
a. Option 1; Epic Motorsports Headers, swaintech coating
i. Fabrication into sourced DKF component exhaust components
1. Exhaust cut-outs and actuator
2. Plug and play cat cells for DEQ PRN
a. I think the cut-out will interchange by my conversation with DKF
3. Is there any obvious fitment issues or additional budget considerations with exception to exhaust fab; ie heat shields, bracket mods, etc
b. Option 2; Super Sprint V1 stepped header, swaintech
c. Summary
i. In building the exhaust and installing, what aspects of the car will be accessible for the “smart” application/address components readily available for labor considerations. Is the engine dropped/pulled?
ii. In addition, in considering exhaust, does it automatically necessitate an EPIC tune? In an effort to avoid multiple “tune purchases”, should the exhaust wait until any consideration for plenum, cams, pulleys, etc.
4. Service Items for a car that has been sitting for 12 years with 151 miles total current date 10-19-19
a. Last Date of Service 12-03-14; miles 149. Dreyer and Reinbold, Inc. BMW/Mini
i. TWS Synthetic oil 1, oil filter
ii. Flush coolant, vent and pressure check system
b. What should even be considered
i. Does it need a “break-in” oil or another service with Total Quartz oil
ii. What is the longevity on valve cover gaskets
iii. Hoses?
iv. Injectors cleaned?
v. Fuel filter change?
vi. Fuel tank flush, treatment?
vii. Flush brakes
c. Inspect wing mounting provisions
d. Inspect Flossman kit for stability; show-car vs HPDE car
2004 BMW M3 Coupe OG Track Dedicated; Graveyard
2002 BMW M3 Coupe Silver Grey; Organ recipient
2002 BMW M3 Coupe Imola Red; project kid car
2007 BMW Z4 M3 Coupe Wide Body; midlife crisis car
MOEDARE140.00
      10-19-2019, 07:15 PM   #2
eggman51
Drives: 2006 BMW Z4 M Roadster
Am mostly posting to follow where you go with this. I might suggest addressing the foramtting - there's a lot of info in your post, and the formatting (or lack of) can make it hard to digest.
I am also dealing with AR Motorsport, planning to do a suspension upgrade with them in the Spring (have to wait a bit budget wise). They seem like great folks, honest, knowledgable, and reasonably priced.
If I understand this correctly, you have a 2007 BMW Z4M Coupe with a very nice wide-body kit. The vehicle has 150 miles on it???
Are you planning a full race conversion? How much street driving, if any, do you plan?
If you have not already, I would replace every fluid in the car (oil, water, diff, transmission, brakes, etc).
Cheers,
Eamonn
      10-20-2019, 09:26 AM   #3
dptmachine
dptmachine's Avatar
I put this together on Word, it copy/paste quite poorly. It is dual purpose to give to Martin for review. It is over zealous, I know. As soon as it posted, I knew it was too much. Blame early AM and eager first drive.
Trying not to miss details myself or have a bunch or redundant labor or things I can do.
I will pull it back a bit and share my progress. It is scheduled to go into the shop and be checked-out, serviced, and begin transformation.
It's fate has been set once the flossman kit was put on in my opinion, no sense in driving around on unmatched suspension and the like.
I wont race it, just track driving and a practice tool for my e46 M3 track build.
      10-20-2019, 10:22 AM   #4
Vanne
Down Under!!
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
Subbed for seeing where your going to take this. . Very nice base to start out with. And as I said I pm, I'd love to see how the front splitter/bumper is attached.
2007 EuroSpec Z4///MC - Building/Developing Z4 GT3
Powered by
      10-25-2019, 05:50 PM   #5
dptmachine
dptmachine's Avatar
2007 BMW Z4 M3 Coupe Wide Body at the shop
I just dropped this car at the shop to get service, look over Flossman kit install, and remove KW's that came with car.
1. I am likely getting MCS 2 way remotes with swap of front knuckles to share parts with my track E46 M3 and project car (lucky dog racing). Rear shares everything the same essentially, front is e36/Z3 style from what I am told. The shop will mock up there wheel sizing tool and MCS suspension on hand.
2. SLR has custom length front control arms with dust shields/boots that can make fitment w/o spacers. I will wait until shop looks it over.
3. I have new set schrick 288/280 I want to install. I thought about swapping this new head off on my Lucky dog car build, get a head from Lang and and install 288/280. Thoughts?
4. Ordering Epic Motorsports Headers and fabricating the parts/pieces I have from DKF remaining exhaust.
5. New Air box needed; recommendations on fitment
6. Pulley kit; keeping AC
7. Epic Tune.
I will be looking for some properly fitting 18" wheels once we decide on suspension configuration. These BBS 19" will be my street "kicks"
I will keep posted on developments
      10-26-2019, 06:53 AM   #6
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
Randy at Epic is top notch youll have zero dramas there.
Powered by
      10-31-2019, 10:48 AM   #7
3GFX
3GFX's Avatar
Drives: 2003 BMW Z4 3.0i
Subbing because ... wow.
      11-04-2019, 11:16 PM   #8
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
With your new coils, how big is your rear gap matey?
Can you shoot us a pic or 2? Predominantly Intrested in your rear gap mate.
Also wondering if your running any inner wheel arches or how that looks on yours? Once again I'd love a pic or 2. Started assembling/dis-assembling my car yesterday..
Thx
Powered by
      11-05-2019, 08:57 AM   #9
dptmachine
dptmachine's Avatar
I am heading to the shop this Friday. The gap will be larger than the "show pics" I anticipate. They have mocked up my coil-over non remotes in the front.
I am not overly concerned. I have decided to go with MCS 2 way remotes with w/o coil-over, thus no immediate need to reinforce the rear shock towers.
I am converting to e46 spindles with custom SLR arms that will accommodate 280's in the front. I have tons of E46 m3 stuff from my previous race car and current build. I will be able to share components, pads etc. They have some mock-ups that I will gets pics.
The shop has dyno'd numerous plenums and their results are bimmerworld plenum supports best power gains. Thus, I am ordering bimmerworld CSL replica, I am dropping of 288/280 cams, new pump disc machined, order Turner power pulley kit, Epic Motorsports headers are ordered with custom y-pipe, and custom Epic tune.
I have never posted pics on thread before; Friday night I will be home and give it a shot. Otherwise I might be asking for help.
      11-05-2019, 09:19 PM   #10
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
The bimmerworld intake is pretty much exactly the same as the Karbonious one and all the other copies. I'd be surprised if there is half a horsepower between them. The vac race box is probably your best bet, but not the best for daily duty. Especially with epic behind the tune, I'd say Randy has probably optimised the tune for that box.
At any rate, you'll find it's a trade off, and unless you have supporting mods in engine, exhaust you'll loose power and torque. Either way, you'll still be trading low down torque for horsepower in the band.
That's just the way it is.
Very keen on seeing how your suspension setup evolves.
Powered by
      11-13-2019, 09:15 PM   #11
dptmachine
dptmachine's Avatar
Quick update;
I dropped off my e46 spindles at the shop. SLR is building custom length control arms now. MCS 2 ways arriving 11-14-19. After conversations with Schrick and Lang racing it is decided that new followers should be employed. I will use the others for my race car Re-fresh. Bimmer world CSL replica arrived today at the shop. As soon at the dampers are on, spring will be selected. i will try and be present or have the shop shoot some pics.
As soon as I get definitive offsets for wheels, give me heads up on some used 3 piece wheels that could work. So far the shop states the offset is 25 for the SLR conversion. HRE gave me rough estimates on a set I found on M3 forum; 100 for break down, 350 for inners, 150 outers, not including refinishing. Ideally find offsets that are close and replace outers. Most likely one off custom 18" for my exact fit; $$$$.
      11-14-2019, 08:13 AM   #12
86Zed
Get off my lawn
86Zed's Avatar
Drives: 6MT
For those interested in pictures - yanked from Canepa and eBay
      11-14-2019, 11:47 PM   #13
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
gday matey, there is no way that et 25 is going to work, even after your SLR arms (which max will put your hub out 20mm.)
You be looking at at least another 1.5 to 2 inches.. unless your talking about your current rims.. (I'd probabilly stick with those) I've currently got 285 on the front, with 2 inches to spare. So even after my gtr arms, will be at least another inch and a half. My front setup is et 28.
Powered by
      11-16-2019, 03:25 PM   #14
2skiddy
Drives: Z4M Coupe
Hi, And may I say the kit looks great on your car, I believe it takes a lot of graft to make the Flossman kit fit perfectly. Getting all the suspension configured is also a challenge, due to the width of the kit and the extra low stance. It may be tempting to think that bolting on the kit produces a wide bodied racer, but for a static show piece it's fine, but for action, maybe not. The reduced ground clearance pushes the tyres up into the top of inner wheel arches, so the metalwork front and rear has to be repositioned upwards to give the suspension travel needed. Also the roll centres need addressing, track widening, diff mounting further up into the shell, etc, etc. It is all doable, but it is VERY different from the standard set up. I wouldn't dream, of putting mine on the road, as the front spoiler would be crunching in no time. I only see it as track car, as that is what it was developed for. I hope you get it sorted, as it is great to see that shape out and about, as not that many have been done. Cheers
      11-19-2019, 09:08 PM   #15
dptmachine
dptmachine's Avatar
Thanks for the input. The is getting suspension now and a more definitive fitment will be surmised. We have already discussed the inner wheel arches will need to be fabbed to accommodate a real track driving situation. I plan addressing the rear diff with 4:10's and orientation next year. I am already dropping serious coin this year. This car will be 97% track, cars and coffee 3%. The shop will be gone to Thunderhill, so I will get some picks next week to check out ride height. I appreciate the feedback, I will definitely be sharing with the shop.
zpost
