      06-18-2019, 12:34 PM   #1
goodboy1451
Drives: BMW 1M Coupe
N54 Water Pump calling it a day
The darned N54 water pump packed up at 62K miles. Besides water pump and thermostat, is there any other parts that should be serviced while the mechanic is at it?
Also where is a good place to buy the parts from?
      06-18-2019, 02:36 PM   #2
Tinsta
Tinsta's Avatar
189
Drives: 1CSL
BMW Dealer for new parts, should be able to get 10% discount with the 4yr + scheme.
Would also change the pipes too, as they begin to perish and at 62k miles its a no brainer.
Full coolant flush with the correct bleeding process should be carried out afterwards too.
If its broke.. Mod it! if not, mod it anyway!
      06-18-2019, 04:01 PM   #3
Snertz
H O O N
Snertz's Avatar
Drives: ein M!
FCPEuro, everything they sell comes with a lifetime warranty, even fluids.
I would replace the plastic mickey mouse ear coolant fitting with an aluminum one too. The plastic one deteriorates with heat/age and can crack. The fitting is just under and to the left of the oil cooler thermostat.
https://www.bimmerworld.com/Cooling/...4-CHC0609.html
U WOT M8?
      06-18-2019, 04:54 PM   #4
CarJunkie
CarJunkie's Avatar
Drives: e82 1M, f87 M2cs
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
I stress my pump running lower coolant targets on track. I plan to replace it next offseason at about 50k miles as preventative maintenance.
1M track toy mods: BMS chargepipe, BMS OCC, ADE FMIC, ADE motor mounts, MadDad/Lightweight Ti exhaust, ADE custom oil thermostat/cooler, custom MHD tune, F10 550i clutch, Ohlins R+T, Vorschlag camber plates, M3 'vert FSB with Turner endlinks, Stoptech Trophy BBK.
1addicts
