BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Coding / ConnectedDrive / Audio-Video / Electronics / Bluetooth / I-Drive & Nav
European Auto Source (EAS)
      08-06-2008, 10:19 PM   #1
1ne
1ne's Avatar
Drives: '08 E92 M3 JZB 6MT
Help on Hard wiring V1
I finally got the fuse tap, however I could not find the 1amp fuse. The smallest I found was a 2amp. Is this ok? Thank you.
      08-07-2008, 08:04 AM   #2
rvacha
rvacha's Avatar
Drives: '08 E92 M3
2008 E92 M3  [0.00]
Yes, this will be fine. Believe it or not the goal of adding the fuse is to protect the fuse in the car! This way if your V1 or its associated power wiring shorts, you will not blow the car fuse and take out other electronics in the vehicle. The smallest fuse normally seen in car is 5A, so your 2A fuse should easily blow before the car fuse
'16 F30 340i xDrive 6MT Melbourne/Black
'08 E92 M3 6MT Jerez/Speed Cloth
'18 F80 M3 6MT SO/CSAT
      08-07-2008, 09:07 AM   #3
1ne
1ne's Avatar
Thank u! I just thought the smaller the better because less current before the fuse blow. 2amp would mean more current. But thanks for your confirmation.
m3post
