Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > Regional Forums > AUSTRALIA
      05-15-2019, 11:17 PM   #1
WatashiEd
WatashiEd's Avatar
Australia
29
Drives: 2015 F82 M4 DCT
SOLD: Brembo BBK (6 pots front 4 pots rear) with rotors and pads
For sale is a set of Brembo BBK (donor vehicle was a 2016 Porsche Cayenne Turbo 958 only travelled ~20,000km), come with:
1. OE Brembo/Porsche Front 6-pot Caliper x 2
2. OE Brembo/Porsche Rear 4-pot Caliper x 2
3. Cross drilled lightweight 2pc Front Rotor 380mm x 2
4. Cross drilled lightweight 2pc Rear Rotor 355mm x 2
5. Full set of light used Brembo high performance pads x 4
6. All fitting bolts and brackets EXCEPT caliper adapters for specific vehicle
Calipers were originally green, which have been stripped and base coated with VHT caliper base coat, one front caliper was painted in BMW ///Monte Carlo Blue to test how will it look like before proceeding further, the remaining three calipers are still in base coat so you can custom any color of your choice too if you wish to. PCD on all rotors have been redrilled to 5x120 by local machine shop, just need custom caliper adapters for car of your choice. Will need minimum 18" wheels to clear.
For comparison to stock f8x m3/4 oe blue brake piston size:
Brembo BBK calipers:
Front 6 pistons: 30/34/36 mm = 52.7 cm^2 (68%)
Rear 4 pistons: 28/28 mm = 24.6 cm^2 (32%)
Total: 77.4 cm^2
Stock f8x m3/4 oe blue calipers:
Front 4 pistons: 40/40 mm = 50.3 cm^2 (67%)
Rear 2 pisotns: 40 mm cm = 25.1 cm^2 (33%)
Total: 75.4 cm^2
Caliper
Brand: Brembo
Body: Cast Monoblock Radial Mount
Caliper Piston Configuration: 6-Piston (front)/4-Piston (rear)
Caliper Piston Design and Insert Type: Inner Pressure Seal/OEM Approved Dust Boot
OEM Part Number: 7PP.615.123.C / 7P0.615.423 / 7P0.615.424
Donor Vehicle: 2016 Porsche Cayenne Turbo 958
Km Travelled: ~20,000km
Disc
Disc type: Cross Drilled Lightweight Rotors
Disc Diameter: 380mm (front)/355mm (rear)
Disc Construbtion: 2-Piece Disc Assembly
Note: PCD redrilled to 5x120 to suit BMW
Friction Material
Pad Compound: Brembo High Performance FM1000
Pad Volume/Surface Area: 107.3 / 95.4
$2,900 pick up only in Northmead due to size and weight, inspection welcome
Sapphire Black M4 | iPE - Valvetronic exhaust | VRSF 3″ catless dp | Bootmod 3 Stage 2 | OEM LED alcantara steering wheel | OEM M4 GTS CF hood | Vorsteiner GT wing | M Performance CF splitter | Vorsteiner CF front lip | M Performance CF side skirt extension | 3D CF diffuser | OEM CF mirror cap | H&R lower spring | Rays Engineering TE37 Ultra Bronze 20x10F 20x11R
      05-19-2019, 05:06 AM   #2
WatashiEd
WatashiEd's Avatar
Australia
29
SOLD
      12-16-2019, 12:10 AM   #3
LOW4LYF
LOW4LYF's Avatar
2163
Drives: E92 M3 & F85 X5M
Pm'd you since I'm super curious where you got the brackets.
Thanks
      12-16-2019, 12:40 AM   #4
WatashiEd
WatashiEd's Avatar
Australia
29
Yea all good, the sale ad was specified WITHOUT adaptor, there is no off the shelf options for our cars, you’ll need to get them custom made, any capable metal fribricator should be able to do it
Thanks
f80post
