Coby Wheel
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > Regional Forums > AUSTRALIA
      03-12-2019, 02:51 AM   #1
DR-JEKL
Australia
898
Drives: Space Grey E92 335i 6MT
FS: F8X M2/M3/M4 6 Pot Monobloc Brembo Calipers
Hey guys I've waited 3 months for these calipers to arrive, and I've changed my mind on the brembo logo design....
Rather then refinishing them figured I'd list them and see if there's a local buyer keen to snap these up at reduced prices (today's price will be closer to $3k) and then buy another set and get them done how I want them instead.
These have been custom powdercoated to match the F8X ///M caliper colour (so the OEM rear F8X ///M calipers will match these).
Brand new calipers with modular mounts to suit 360mm E9X 1M rotor or F8X gen 380mm front rotor, pad mounting clips etc, and braided brake lines.
These utilise bleed nipple caps and are of course street legal. They're a massive caliper but are lighter than OEM (these are 3.3kg oem is 5.4 kg) and utilise pads much larger than OEM with much larger surface area and thus increased braking performance.
These calipers also utilise slide pins for securing the brake pads, so changing pads is a 5 minute job and isn't as cumbersome as the OEM pads and a 380mm F8X rotor and these calipers can squeeze under a 18" rim!
No pads are included I can help you select pads depending on what rotor you wish to run.
Happy to post Australia wide at your expense and responsibility
Price: $2600
f80post
