BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 (E90 / E92 / E93) > General M3 Forum (E90 + E92 + E93)
European Auto Source (EAS)
      03-03-2019, 12:19 PM   #1
M3PR
M3PR's Avatar
54
Drives: E92 m3
Smoke test on ess supercharged
Today i perform a smoke test in my m3 ess 650. It show to cylinders leaking at the boot. I have bought new boots before and use brand new clamps on the lower side and tbolts clamps on top. Both are peaking from the lower side with only 1 psi o on the smoke test. Not alot of smoke but evidently leaks. Has anyone consider buying after market boots with real turbo clamps? If so what brand? The reason indid this is that inony manage 545 and 560 on 4th i couldnt see any more tha 6.8psi on the dyno. Any help will be appreciated thanks
Ps i have seen 8 psi but that is if i jump on the rev
      03-03-2019, 02:34 PM   #2
Solo_M_Tech
Solo_M_Tech's Avatar
Drives: 2014 M5 6MT
2014 BMW M5  [0.00]
you'll likely run into clearance issues with the throttle body linkages. I'm interested in seeing what you come up with. I've never had a leak using any ESS kit and the stock clamps.
2014 M5 6MT
      03-03-2019, 03:08 PM   #3
bvrider1
Drives: e90 m3 + f80 zcp
I just replaced all 8 intake boots with new ones and used the following clamps.
Oetiker clamps with a 9mm band width and ~74mm diameter
https://www.mcmaster.com/5574k19
I wonder if you can use these clamps. When you did your smoke test the smoke leaked from what location?
      03-03-2019, 08:17 PM   #4
M3PR
M3PR's Avatar
54
Drives: E92 m3
It leak from the bottom. The clamps used are oem brand new and also have new boots. The car os fast but i know there still room for improvement. It ran 136.7 in a 1/2 mile roll race. Just noticing i didnt hot the 8-9 psi for ess 650 kit. Bought new tensioner new belts. And still seems to have a leak. Just check with the smoke test ando so it did. Will check boost reading with mew clamps but just wanted to know if there anyone using other boots and clamps tonget thebmax boost
      03-03-2019, 08:20 PM   #5
Properstyle
Drives: 2011 e90 ZCP m3
136? Sounds like you have some issues going on I ran 155 in Dallas in my chrrrnt setup and when I had my old m3 it did 149 at heaven landing ga in the 1/2 mile both froma dead stop.
      03-03-2019, 08:21 PM   #6
M3PR
M3PR's Avatar
54
Drives: E92 m3
That was what i thought, are you getting max boost on every gear? Do a smoke trst and see what you get. It seems that everyone is just satisfy with boost at lower levels even with a leak. Thats why we have a. Very different variaty of dyno sheets.
      03-03-2019, 08:25 PM   #7
M3PR
M3PR's Avatar
54
Drives: E92 m3
I know when i hit 5th gear it stop pulling like it should. Brande new plugs and coils. I need to get those leak solve. But just tellong ppl here to check with smoke test of they for sure have a leak. Will solve the problem and see from there
      03-03-2019, 08:26 PM   #8
M3PR
M3PR's Avatar
54
Drives: E92 m3
Any aftermarket boots and clamps available
      03-04-2019, 05:54 PM   #9
bvrider1
Are you also running the brackets that keep the manifold from lifting?
      03-16-2019, 09:47 AM   #10
M3PR
M3PR's Avatar
54
Drives: E92 m3
No
m3post
