02-24-2019, 06:44 PM | #1 |
Rep 2,160
Does a used DCT transmission need to be coded to work?
Helping a friend swap in a used low mileage DCT transmission into his E90 next weekend.
Has anybody done this job before? Pretty straight forward? It looks quite easy from just eyeing it. I've been hearing conflicting info that the Getrag DCT transmissions are VIN coded and the mechatronics control units needs to be coded with the correct VIN in order for it to work. Any truth to this? I also heard that if you install a used DCT tranny from the same year that no programming is needed. Any help would be greatly appreciated! |
02-24-2019, 06:54 PM | #2 |
Rep 1,612
Have you identified it being a dct unit issue or a mechatronic issue?
If it's confirmed the unit in bad, you need to take the side pan off and swap his mechatronics into the new trans A clutch relearn will also need to be done after bringing the trans up to 80degC via bmw scam tool or auto logic |
02-24-2019, 07:01 PM | #3 | |
Rep 2,160
Is there any way he can use the mechatronics from the donor DCT? |
02-24-2019, 07:03 PM | #4 | ||
Rep 1,612
It's really easy to sway the mechatronics, takes maybe 30 min and you can change the side pan gasket which is notorious to leak |
02-24-2019, 07:06 PM | #5 |
Rep 1,612
I would also change the soft cooler lines on the side of the trans running to the top heat exchanger while your at it
They go bad all the time if his aren't already leaking |
02-24-2019, 07:22 PM | #6 | |
Rep 2,160
https://www.rpmmotorsport.net/collec...amming-service Ouch $600 for the service, that's about how much he paid for the transmission itself! Looks like swapping the mechatronics it is! Last edited by DanMpower; 02-24-2019 at 07:40 PM.. |
02-26-2019, 10:08 AM | #8 |
Rep 303
Sounds like you guys are trying to open a can of worms that doesn't need to be opened. If his stock DCT is running fine I'd leave it alone and keep the fresh spare in the garage.
02-26-2019, 10:17 AM | #9 | |
Rep 2,160
I'm always there to lend a helping hand if he needs it. |
02-26-2019, 12:38 PM | #10 |
Rep 303
To be honest if he's going that route he might want to replace the DCT clutches as by 140k miles I'm sure they're worn. It would be dumb to replace a high mileage tranny with a low miles one but still be using the 140k miles worn clutches.
02-26-2019, 01:26 PM | #11 | |
Rep 1,005
Drives: GMC Sierra
I wouldn't do this as a PM item. Huge can of shit not worms. If your friend wants to do PM do RBs if they haven't been done. Or some of the countless other things that are considered PM. Set that DCT in storage for when it is needed or can be flipped. IMHO
We grow food to feed the animals so we can eat the animals
tooloud10766.50 |
