01-21-2019, 03:26 PM | #1 |
Rep 591
what can be damaged by a pothole?
hit a pothole last night, now i'm getting some vibration from the front left (pothole was on the left) when braking hard. constant speed/acceleration driving seems somewhat ok, but at higher speed (> 80 mph) seems to feel some vibration at steering wheels as well.
will go visit a wheel place to check for bents. what else should i watch for? what are the suspension components tends to get compromised by a pothole? or from what the symptoms are, any input on what might be wronged by the pothole? |
01-21-2019, 03:29 PM | #2 |
mTekMods
2142
Rep 2,902
Thrust arm bushings and or more likely a bent rim.
2011 Frozen Black/Fox Red E90 M3 650+WHP
G-Power Supercharged First DCT to Manual Conversion Worldwide KW CS, BBS RI-A, BW Headers, Snow 2.5 |
01-21-2019, 04:53 PM | #4 |
Save the manuals!
6015
Rep 6,746
This. Vibrations around 80mph in the steering wheel are a textbook symptom of out-of-balance and/or bent wheels.
Sure, but that's not causing OP's symptoms.
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
01-21-2019, 05:57 PM | #7 |
Rep 477
The M3 wheels are pretty durable from my experience. Get them checked out, but most likely either a balance or alignment issue. If not, the only possible conclusion is bent rims.
Current Car List
2020 F87 M2 CS - Hockenheim Silver 2020 F97 X3M- Phytonic Blue |
01-21-2019, 06:24 PM | #8 |
Rep 713
01-21-2019, 07:44 PM | #9 |
Rep 10,616
Do the vibrations change under braking? A pothole usually won’t ruin a bushing. It can bend a wheel, unbalance a wheel/tire, throw off an alignment, damage an upper strutbearing. Very rarely, bend a control arm. I’d suspect first a wheel or balance.
01-21-2019, 08:04 PM | #10 | |
Rep 591
While the vibration at high speed feel more like typical bad wheels / spacers steering wheel shake... |
01-21-2019, 08:46 PM | #12 |
Rep 10,616
If braking changes that is a sign. Braking puts pressure on the suspension. I’d add tie rod to the front strut rod bushings and wheel balance/bent wheel list.
01-22-2019, 08:28 AM | #13 |
Rep 52
I hit a small speed bump once. Had a quick jolt that kills you a little. Ended up bringing it to the dealership and it bent my control arm.
Active AutoWerke Signature Exhaust, AA Test Pipes, AA Tune, Vorsteiner GTS-V Rear Diffuser, Vorsteiner Front Lip
01-22-2019, 11:57 AM | #14 | |
Rep 2,138
Drives: 2011 E92 M3
BMW wheels are stout, but fairly soft and they will bend. They can be fixed.
2011 E92 M3 - 6MT, ZCP, ZF LSD, ESS G1, Some other goodies... |
01-22-2019, 12:59 PM | #15 |
Rep 950
Wont account for the symptoms necessarily but Ive had two outcomes in the past, with my previous m3, severe bubbling, expansion of inside tire wall. Another time with a mazdaspeed, bent control arm albeit this was more like a ditch you seen on Northeast US roads after a snow storm.
01-22-2019, 08:25 PM | #16 |
Rep 224
Very easy to damage a tire. Radial/sidewall can all be damaged by an impact. You may have also just knocked the balance off; wheel weight seperation. Any number of things. Start with the cheapest thing, which is to have the wheel/tire road force balanced. You can ask for the tire to be dismounted and the wheel checked for an extra mount fee, which is minimal.
11 BMW E93 M3-- 06 BMW Z4M Roadster
99 BMW M Coupe -- 85 BMW M635CSI 97 M3 Coupe (Track)--95 BMW M3 Coupe 91 BMW 850i 6MT--20 Ram 1500 16 Chevy Tahoe 4WD |
