11-17-2018, 04:48 PM | #1 |
Rep 12
Drives: 2009 E90 M3
Issue with charging system
Recently, my e90 gave me a “low battery voltage” warning...thinking that a spirited-highway drive might have helped, i went on a drive and 16 miles later all kinds of warning lights started to come on until the engine quite at 80mph down the highway. Thought it was the battery, so i replaced it with a pep boys one. Did not drive the car for a week; when i decided to go get a hair cut, the car decided to do it again. I gave the old battery a good charge on a trickle charger and placed it on the car. All systems (settings menu) check “OK” but i still have a message “increased battery discharge”. Does this mean that my charging system took a dump on me?!
11-17-2018, 05:27 PM | #2 |
Rep 3,726
Drives: 2018 M2
Something might be draining your battery. One common issue is if you’ve got EDC. The module stays on even when the car is off and drains the battery. If that’s the case you’d need to replace whichever EDC modules are doing this. Reason I don’t think it’s your alternator is you said you swapped for a new battery didn’t drive it and it still said low voltage. You could try charging the new battery, it’s not impossible the new battery was nearly drained when it was sold
11-17-2018, 05:48 PM | #3 |
Rep 10,616
Car should not die once running if alternator is good since it will provide power to run everything even if battery is no good.
Check your grounds. There are 2 under the motor on the sides. Bad grounds can screw up all sorts of things. |
11-18-2018, 06:04 PM | #4 |
Rep 2,362
Drives: G87 M2; E92M3 MT&DCT; M3 euro
Would you care to point out exactly where? I think I have a battery leak...
Pass me if you can.
11-19-2018, 04:15 PM | #5 |
Rep 12
Drives: 2009 E90 M3
Charging system left me stranded...again!
started the car this morning, all systems checked “OK”, si I decided to get some errands done. Three hours later...car won't start; increased battery discharge annunciation displayed, then low battery charge...WTF!!!! i had put the Carly reader and showed the battery/charging parameters good (shortly after I installed the completely charged battery) I’m guessing, I might as well take it in the a**, and take the car to the dealer and have it checkedit’s embarrassing to be seen in a flat bed with my freaking M3 on it for the third time in a month!!
11-19-2018, 04:34 PM | #6 | |
Rep 2,336
'09 ///M3 Sedan - Jerez Black/Fox Red Ext.
'09 335i Coupe - Alpine White/Black - SOLD |
11-20-2018, 11:01 PM | #7 |
Rep 12
Drives: 2009 E90 M3
Too late 😐
I just had it towed to Lone Star Bavarian (BMW Dealer/Service Center) I should find out tomorrow what it is...I didn’t think of Rock Auto for foreign cars! i’ll Let you guys know how it went. Fingers crossed!
11-21-2018, 03:05 AM | #8 | |
Rep 2,336
https://www.rockauto.com/en/parts/va...generator,2412
11-21-2018, 12:12 PM | #9 | |
Rep 12
Drives: 2009 E90 M3
Too late 🤭
11-23-2018, 04:54 AM | #10 |
Rep 91
Same happend me when I replaced my battery.
Did you register the new battery to the car? I replaced my battery with an identical new BMW one. Everytime I started the car I got increased battery discharge and the clock reset. Registered the battery to the car and it hasn't done it since. The car needs to be told it has a new battery so it may think it still has the old bad one installed which is the reasoning for the errors. |
11-23-2018, 06:51 AM | #11 |
Rep 2,442
Drives: 2022 M3 6MT
So important to remember that the car only charges the battery when coasting and your foot is off the gas. Sitting idle won't help it.
Regardless of what the issue is here, get a tender and hook it up - the amount of electronics these cars have now really strains the system and keeping the battery topped off will help a great deal. I'm still on my original battery and it's 9 years old.
2022 M3 6MT - Portimao Blue Metallic
2022 X3 M40i - Tanzanite Blue Metallic |
scrammer421.50 |
11-23-2018, 08:47 AM | #13 | |
Rep 7,110
11-23-2018, 09:15 AM | #14 | ||
Rep 2,442
Drives: 2022 M3 6MT
Modern BMWs have a digital gauge on the dash that will light up blue with a battery icon when you take your foot off the gas. The M3 does not have this gauge obviously, but the system is still there.
11-23-2018, 09:24 AM | #15 | |
Enthusiast
117
Rep 150
The main reason for registering the battery is for the alternator to reset the charging pattern based on the battery installed. The alternator varies the charging pattern based on the age and power output of the battery and when you re-register the new battery you are basically resetting this pattern for the optimal charging of the specific battery. |
11-23-2018, 09:27 AM | #16 | |
Enthusiast
117
Rep 150
Good luck! |
11-23-2018, 09:28 AM | #17 | ||
Rep 2,442
Drives: 2022 M3 6MT
11-23-2018, 04:39 PM | #19 | |
Rep 7,110
11-24-2018, 05:02 AM | #20 | ||
Rep 2,442
Drives: 2022 M3 6MT
We see it so many times on the forums here with battery issues - I always say to keep the car on a charger and see if that solves it before chasing electrical gremlins through the car.
11-24-2018, 06:38 AM | #21 | |
Rep 7,110
Cheers |
11-24-2018, 09:28 PM | #22 | ||
Rep 2,442
Drives: 2022 M3 6MT
Basically, when the car coasts, the battery gets juice. During acceleration, the alternator is uncoupled.
