11-07-2018, 02:33 AM | #1 |
Rep 17
Is this normal?
Hey guys. I'm currently looking at this car to buy. The only problem that I'm a little bit worried about is this part here.
View post on imgur.com Is that supposed to come off like that? The owner said it is normal wear and tear because the car sits low? It's a plastic piece I think. Is that anything I should worry about? |
11-07-2018, 04:54 AM | #2 |
Rep 10,616
It’s pretty common for the front undertray and the two sudecwings to get trashed, particularly on lowered cars. When they rub or hit something they can push back against the front side of the wheel liner. The complete undertray might be around $500. If your wheel liners are wrecked you would need those as well.
11-07-2018, 05:22 AM | #3 |
Rep 4,014
If it needs an undertray those are around $400 from deansbimmer
Fender liners around $125 per side. Ask whomever you are having do the PPI to look to see if they liners just need a new clip or two. As far as the undertray, I have seen cars for sale completely missing them. Again, make sure the ship doing the PPI checks to see if it's even there. |
deansbimmer3750.50 |
11-07-2018, 07:32 AM | #4 |
Rep 368
That looks like it just popped out, I wouldn't worry about that. Easy fix. Highly doubt you even need to replace that.
Like some others have said there is an under-tray that these cars have that gets destroyed pretty regularly. So much so that 3rd party vendors have made a metal replacement. https://www.turnermotorsport.com/p-3...BoCmEgQAvD_BwE |
11-07-2018, 10:56 AM | #5 |
BimmerPost Supporting Vendor
3751
Rep 2,907
Drives: 2011 E93 M3
Here is the fix for the broken and missing undertray parts.
https://www.m3post.com/forums/showthread.php?t=1439553 |
11-10-2018, 12:22 AM | #6 |
Lord Scrip
1813
Rep 3,013
Drives: 2011 M3 Coupe
Corner piece needs replacing. Not a big deal at all. $90 and 2minutes to replace.
11-10-2018, 11:50 AM | #7 |
Rep 1,932
Drives: 2013 E92 M3
