BMW M3 Forum (E90 E92)
BPM
      11-03-2018, 03:18 PM   #1
douglee25
Drives: E36 M3
Idler Pulley Replacement - Tip
I mentioned this in the other post, however if you don't read until the end of the post, you may miss it. Hopefully it helps someone....
The idler pulley near the water pump with either the offset or centered hole (depending on build date), that is rather inexpensive at $25-$30. However, the two tensioner pulleys are hella expensive because they don't sell the pulley separately ($160 & $185). I did manage to pull those two apart afterwards. Each tensioner uses the same pulley.
Measured Pulley Dimensions -
1. OD - 70mm
2. ID - 16.95mm
3. Width - 26mm
Dayco has two pulleys listed -
Pulley #89144 -
OD - 70mm
ID - 17mm
Width - 25mm
Pulley #89133
OD - 70mm
ID - 17mm
Width - 24.5mm
Both said they can be used for 6 rib belts. They list for ~$25 on Amazon. This may be a cheap alternative than replacing the entire assembly which isn't needed.
Doug
      11-03-2018, 03:42 PM   #2
RC Post
Drives: E90 M3 6MT
Nice. Post pics if possible for visuals
I may have to do mine soon. Mine are starting to get loud..
      11-05-2018, 08:56 PM   #3
douglee25
Drives: E36 M3
See attached....
      09-25-2020, 02:43 AM   #4
LKN624
LKN624's Avatar
Germany
274
Drives: 08' E90 M3 and 08' E92 M3
Do you know the torque for these bolts? Since they are a Silver Coated M10 10.9 Bolt...according to NEWtis...it says 56Nm but I am not sure...
      09-25-2020, 06:44 AM   #5
douglee25
Drives: E36 M3
I don't offhand. Recommend just snuggling them up. You break one of those bolts and it will surely ruin your weekend.
      09-25-2020, 08:53 AM   #6
LKN624
LKN624's Avatar
Germany
274
Yeah I am already getting frustrated. I got everything put together and there is a HORRIBLE vibration that I can feel through the entire car when the car is idling and running. No idea what the hell is going on.
      09-25-2020, 09:38 AM   #7
douglee25
Drives: E36 M3
Snuggling? Aye too early. Try snugging rather.
Anyway, way the vibration there before? Take the belt off and run the car. Vibration still there?
      09-25-2020, 12:58 PM   #8
msan
Drives: 2011 E90 M3 / 2012 X5 35i M Sp
DontTellMyWife pointed to this INA pulley as a direct replacement pulley for the tensioner pulleys. https://www.m3post.com/forums/showpo...7&postcount=44
INA 532 0342 10
Diameter [mm]: 70.00
Width [mm]: 26.00
$20.99 on FCP
https://www.fcpeuro.com/products/bmw...li-11281440237
$23.00 on Amazon
https://www.amazon.com/Drive-Idler-P.../dp/B00FBQM344
Link on INA's catalog:
https://aftermarket.schaeffler.com/e...312-5320342100
      09-25-2020, 04:44 PM   #9
fth001
Drives: 2008 JB M3
I had this same issue, did my motor mounts but nope...still there. It ended up being a crack in one of the cooling fins on my fan. $900 fix but my vibration is gone.
      09-25-2020, 05:53 PM   #10
LKN624
LKN624's Avatar
Germany
274
Tried that...but the problem is it feels all normal until I drive about 30 feet and then it starts vibrating the entire car. I might think it may be the 10mm socket i dropped somewhere in the engine bay...lol I need to take off all of the engine underbody stuff to check to see if its wedged in somewhere somehow...
      09-26-2020, 05:36 AM   #11
LKN624
LKN624's Avatar
Germany
274
You know what I forgot to do? Clear the DME code for the Fan...it might be turning on super fast...
m3post
