10-03-2018, 10:39 PM | #1 |
Rep 565
Where do these screws and nuts come from?
I picked up an e93 about a month ago, and had the car in a local shop for some work done shortly thereafter (rod bearing, engine mount, under tray replacement). I was tinkering around the engine bay tonight and saw these two pairs sitting inside the leaf catch tray on the driver’s side. I’m not sure if they had always been there since I first bought the car, or were recently placed there by the mechanic who worked on the project a few weeks back and forgot to put them back onto their original locations.
Any ideas where they may be from? |
10-03-2018, 10:56 PM | #2 |
Rep 836
Drives: Jerez E92 M3 ZCP "12"
If I were you, I recommend sending your pictures to the shop and ask the mechanic or mechanics who worked on your M3....possibly forgot to put them back and may remember where they go, which I assume they should recall where they came from. Goodluck
10-04-2018, 05:35 AM | #3 |
BimmerPost Supporting Vendor
3751
Rep 2,907
Drives: 2011 E93 M3
The two phillips head screws are not OEM screws. They don't belong in the car. Not to say someone didn't replace missing hardware with the wrong ones.
The torx screws are applicable to many locations in the car. You'd just have to have a look around so see what's missing. That screw type would be securing something into plastic or a speed nut. |
jdamore432.50 |
10-04-2018, 08:41 PM | #4 |
Rep 230
Since you found it close to the driver's side leaf catch tray, check the air filter housing. It has numerous of those used for it.
'04 E46, '08 E93, '16 F22 M235i, '17 i01 i3
10-04-2018, 08:52 PM | #6 |
3751
Rep 2,907
Drives: 2011 E93 M3
The engine air filter housing screws are silver, but not washer screws like the ones in the picture. These fillister head screws are what are supposed to be in the air filter box.
10-05-2018, 09:17 AM | #10 |
Rep 12,726
I've had the bumper and whole bottom of the shielding off and none of my screws looked like those.
Instagram; @roastbeefmike
10-05-2018, 09:44 PM | #12 |
Rep 565
07-01-2022, 02:42 AM | #14 |
Rep 4
The Torx screws apply to many locations in the car, so it might be hard to find where exactly they are from. You'd just have to look around to see what's missing (if anything is missing at all). Based on the picture you added, it might be from the air filters. It has a bunch of them there holding it. The two Phillips head screws are not OEM screws. They don't belong in the car. In case you'll miss any other screws, I sued to buy mine from https://www.scrooz.com.au/screws/decking-screws/, and they always had anything I needed.
