BMW M3 Forum (E90 E92)
Mporium BMW
      07-25-2018, 06:58 PM   #1
GORDON.M3
GORDON.M3's Avatar
Drives: E92 M3 • F25 X3 M-Sport
DIY BMW OEM Carbon Fiber Clear Coat Repair
So... I purchased a OEM high-kick spoiler from a member with an E93 a while back and it was damaged.
The spoiler was an OEM E92 M3 high kick spoiler.
The clear coat had been chipped and cracked. I was told that it could be re-cleared/re-coated, so I thought to myself why not.
After taking it to several body shops and random "Carbon Fiber Repair" shops, they all quoted me ridiculous amounts of money for the small repair. The most ridiculous shop wanted to charge me $600!
Started to Google carbon repair tutorials and what not. Stumbled upon this one, where the guy repaired some cracked clear coat from his rear diffuser.
Following the same techniques, I was able to successfully repair my the rear spoiler.
Intial damage:
After sanding with 200 grit, then 400 grit, then 800 grit.
Applied a layer of the epoxy resin with a foam brush as demonstrated from the youtube video linked above.
24 hours later, after the resin has cured.
The end result, I leveled the clearcoat with 1000/2000 grit sandpaper and buffed it till it was shiny. Looks pretty damn good!
Can't even really tell it was damaged before!
So I hope these photos helped anyone whos trying to repair their own carbon fiber at home. Don't be afraid to do it, it was really easy and the results are awesome!
INSTAGRAM: GORDON.M3
North American Mr12Volt Carplay/Android Auto Distributor
DINAN | EVOSPORT | VAC | ARP | RD SPORT | NEEZ | EIBACH | CSF | IND | BILSTEIN | KLASSEN | BREMBO | ENDLESS | BBS | BPM SPORT | PROJECT MU | EVENTURI
m3jala543.50
AnotherM3224.50
shimmy232350.00
tdott3942.50
dozaiya236.00
      07-25-2018, 11:48 PM   #2
m3jala
Drives: Jet Black 2013 BMW M3
Thanks for sharing. I am sure this will give confidence to someone who needs to make a repair and is being quoted from another dimension to fix it.
GORDON.M31422.50
      07-26-2018, 04:19 AM   #3
last1left
last1left's Avatar
175
Drives: e92 M3
Good work I've done similar easy it just takes patience resin is easy to work with.
GORDON.M31422.50
      07-29-2018, 10:29 AM   #4
shimmy23
F15 daddymobile
shimmy23's Avatar
2350
Drives: GS X5
Nice! Thanks for sharing
GORDON.M31422.50
      08-30-2018, 07:34 AM   #5
cmyE93M3
cmyE93M3's Avatar
Drives: E93 M3
Awesome.
2008 E93 M3 | SSII | HRE P40's (Sold 2018)
2011 E90 M3 | Jerez Black (Sold 2019)
2019 Lexus IS300 (lasted 3 months)
2020 Toyota 4Runner TRD (fun truck)
2014 Tesla Model S P85 (wicked car)
2011.5 E92 M3 | Space Grey | ADV.1?s
GORDON.M31422.50
      08-30-2018, 07:39 AM   #6
EJT86
EJT86's Avatar
Drives: 2018 M2
  [0.00]
2018 BMW M2  [0.00]
Great job! I need to do this to my diffuser
GORDON.M31422.50
      08-30-2018, 08:27 PM   #7
GORDON.M3
GORDON.M3's Avatar
Yes, diffuser is quite common to have cracks, the same method works for rock chips/rashes on splitters.
      11-18-2018, 11:04 AM   #8
LPM3
Drives: 2011 E90 M3
Which brand resin did you use?
      11-18-2018, 11:19 AM   #9
GORDON.M3
GORDON.M3's Avatar
Anything for countertops will work, some have higher levels of UV resistance than others. Any kind of two-part liquid epoxy resin will work. The best is the kind for marine boats.
      11-18-2018, 11:54 AM   #10
LPM3
Drives: 2011 E90 M3
Thanks!
      11-19-2018, 11:37 AM   #11
GORDON.M3
GORDON.M3's Avatar
Thanks!
no problem, let me know how it goes!
      01-09-2019, 06:39 PM   #12
GORDON.M3
GORDON.M3's Avatar
oh and I forgot when applying the resin, use this kind of brushes!
      01-09-2019, 06:58 PM   #13
InnerBlueSkies
InnerBlueSkies's Avatar
1093
Drives: 2008 E90 M3
You did an awesome job my friend. Thanks for sharing.
GORDON.M31422.50
      03-09-2019, 10:34 AM   #14
classic_erik
classic_erik's Avatar
Drives: 23' X7 40i M Sport
I am so impressed with your work.
Do you think I have a shot with this F15 front splitter? Damaged before installing so should be easier to work with...
      03-09-2019, 12:14 PM   #15
GORDON.M3
GORDON.M3's Avatar
Thanks!
You can repair it but since its quite a large area you will need to do a lot more sanding and prep work before you can apply the resin.
      04-01-2019, 10:59 AM   #16
classic_erik
DIY Completed! Thanks for your courage and guidance this was really easy...
ToddinTN504.00
GORDON.M31422.50
      04-01-2019, 10:34 PM   #17
GORDON.M3
GORDON.M3's Avatar
Glad the guide was able to help you restore your part!
m3post
