07-20-2018, 02:37 AM | #1 |
Rep 30
Drives: F82 M4 Competition + F20 118d
Snow Chains on M4 Competition
Does anyone in Australia have experience fitting snow chains or alternatively, winter tyres to an M4 Comp? I'm sure BMW will say snow chains can't be fitted, as they do on all their M Sport models, however I've managed to successfully fit them in the past. Maybe the M4 Comp is different 'though. If you've had success with this can you please advise details?
An (expensive) alternative is winter tyres, however National Parks will still insist on chains for a 2WD vehicle even if its got winter tyres. I'm in Sydney visiting NSW ski resorts so will rarely need them anyway, but better sure than sorry. |
07-21-2018, 01:18 AM | #2 |
SCHNELL
226
Rep 835
Couldn't fit them to the X5 with 20's last week, but still legally had to carry them ;/ Would not even entertain the idea of taking my F80 to the snow - but there's lots of threads from US and EU on it. https://f80.bimmerpost.com/forums/sh....php?t=1046456
Alexo8.50 |
07-21-2018, 01:39 AM | #3 |
Rep 1,165
Drives: f83 / E93 335 / E70 X5 40d
winter tyrea in Australia?
in the EU, the winter tyres have studs in them, so no need for chains. i think the reason you normally cant fit chains, is the lack of clearance - you orobably need some 18"s. then the 18"s could double up as track day tyres, but then you would want semi slicks... oh, such a 1st world problem! |
08-01-2018, 02:27 AM | #4 |
Rep 30
Well I've found there are Nokian snow tyres out of Melbourne but they require a set of 18" rims instead of the 20's so thats out of the question due to cost. I've also found Konig CL10, 105 chains that might do the job. They fit the M4 Comp 285 x 30 x 20" setup. CL10 refers to 10mm clearance required all round so I think I'll give them a try. I've only used chains twice in 30+ years of driving from Sydney to Thredbo 2 - 3 times per year but legally they've got to be carried.
I've spent a lot of time driving in the worst winter conditions imaginable in Canada with both summer and snow tyres and the snow tyres are pretty much bulletproof on any drive layout you like. AWD/4WD with summer tyres is much, much worse than 2 WD with snow tyres. |
08-01-2018, 05:38 AM | #6 |
Rep 357
I saw an e92 parked up at Hotham on a sloped driveway with 2 inches snow and it's tyre tracks behind it down the drive. Think he had 18's and decent winter tyres.
Having moved from the UK I was surprised by the fact that snow tyres aren't approved attire in Australia but some battered, badly fitting rented chains that will smash your body work, wheels and arches up whilst sliding you into a tree under braking are approved. Common sense prevails. |
08-02-2018, 03:20 AM | #7 |
Rep 320
There is a place in berridale that rents proper 4wd's. Just rent one of those, they will securely store your the M4
http://www.alpenautorentals.com I live in jindabyne in winter and drive up everyday. As you say you rarely need chains to get to thredbo. However, if you do, you will have problems with the M4 with the konig chains. You will still have very little front wheel grip for braking or turning. Also, the low ground clearance could be a problem if you are in a car park and get snowed in. You could easily get beached on the cars belly, or have snow pile up in front of the spoiler If I were you I would look very closely at the weather forecast. If it looks fine for the period you are there you could take a punt. If there is going to be low level snow it is not worth the risk. I would never drive our M4 up there in winter! |
Alexo8.50 |
08-02-2018, 10:47 AM | #8 |
not that guy
112
Rep 83
Winter tires in the EU don't have studs in them. Some regions in the Nordics do, but only there.
I've taken my M4 on resorts in many occasions, with the stock 640m wheels wearing 255 winter Contis (830 i think) No drama, no problem, and can handle the snow just fine. I've even been in a resort that is full of ice and snow, where chains were recommended but not mandatory - had little issues. The only problem is that the rears go quite quickly to 4mm depth, which is the limit for proper winter use, but that's a small cost for the amount of use I've gotten out of the car. A good set of winters and a nice LSD can go a long way. I think that my set is not even that good in the snow, a pair of Nokians would probably be even better, but my snow use is not that dramatic and is mostly the occasionaly snowy day in Zurich.
08-02-2018, 07:12 PM | #9 | |
Rep 30
08-02-2018, 07:14 PM | #10 |
Rep 30
