BMW M3 Forum (E90 E92)
      07-15-2018, 02:41 PM   #1
PACarGuy
PACarGuy's Avatar
Drives: 2012 E92 M3 DCT ZCP
Replacing side belly pan felt covers
I've been searching and have come up empty. Anyone got a quick write up on replacing the front side felt belly pans (left and right)? I'm guessing it's pretty straightforward, but wanted to check before I jack up the front. Does the center belly pan and fender liners need to be loosened first?
TIA.
2012 E92 M3 | ZCP | DCT | Space Grey Metallic | Black Novillo | BE/ARP | MPE V2 | AA green filter |BMW CF Rear Spoiler, RW Carbon Diffuser, CF Front Splitters | DTEC 160W Angel Eyes
      07-15-2018, 03:15 PM   #2
EJT86
EJT86's Avatar
Drives: 2018 M2
  [0.00]
2018 BMW M2  [0.00]
TIA.
No you can leave the center part alone, the side pieces have to go in after the center piece is in so you don’t need to touch it and leave the fender liners alone too. It is straight forward just make sure you reuse the old clips because new ones will be way too tight and will spin and tear the felt when you try tightening the screws
PACarGuy679.00
      07-15-2018, 03:29 PM   #3
PACarGuy
PACarGuy's Avatar
Perfect, thank you. Good note on the old clips since I bought a bunch of new ones just in case!
      07-15-2018, 04:03 PM   #4
EJT86
EJT86's Avatar
Drives: 2018 M2
  [0.00]
2018 BMW M2  [0.00]
Yea the new ones are useless. The screw will screw in half way then the whole clip will spin and tear a chunk off the felt. You can’t even tighten it enough to hold the pan on before it tears
      07-15-2018, 04:35 PM   #5
PACarGuy
PACarGuy's Avatar
Of course, now that I say that, I know I'm missing at least one of them, so that will be interesting.
      07-15-2018, 04:38 PM   #6
EJT86
EJT86's Avatar
Drives: 2018 M2
  [0.00]
2018 BMW M2  [0.00]
You don’t NEED all of them the felt pan will be destroyed in about 18 months anyway. If you really want to try a new clip Drill the hole a little wider first
PACarGuy679.00
      07-15-2018, 04:53 PM   #7
BOOF-M3
BOOF-M3's Avatar
Drives: 2011 M3
Custom M3 Aluminum Undertray Replacement 2008-2013 https://www.m3post.com/forums/showthread.php?t=1439553
PACarGuy679.00
      07-15-2018, 05:03 PM   #8
PACarGuy
PACarGuy's Avatar
Thanks. I did come across that while searching but I already bought a left side pan replacement. Maybe once the next set gets ragged I'll replace the whole thing. The rest seems to be holding up ok. It's really just the left side.
m3post
