07-02-2018, 09:53 AM | #1 |
Rep 39
clunk sound
sup everyone I was hoping to get some help
I'm in the process of buying a used BMW M3 from a local bmw dealership and when I took it on a test drive I could hear a clunk sound coming from the back of the vehicle every time I took a turn... not sure what it is (bushings, control arms, rear diff) but I told the dealer that needed to be fixed first before I would buy the car. Today I get a call from the dealer advising me that the car was inspected and all it needs is for a "rear clutch differential adjustment" to be done. Does this sound normal? I've never heard of a differential adjustment before. I appreciate all the feedback thank you! Last edited by Jm5900; 07-02-2018 at 12:04 PM.. |
07-02-2018, 07:10 PM | #3 |
BimmerPost Supporting Vendor
3752
Rep 2,907
Drives: 2011 E93 M3
Oh, no biggie, just the everyday rear clutch differential adjustment? Is that like the headlight fluid you need to top up at each oil change? SMH.
If there is a clunk back there on turns then its a broken bushing or part not an adjustment. |
07-02-2018, 08:10 PM | #4 |
Rep 973
Drives: 2012 E92 M3 DCT ZCP
The M3 has a limited slip variable locking differential with a viscous coupling, which can fail (and cause clunking). It can be rebuilt, but I didn't think there was an "adjustment" that can be made to it to fix that issue...maybe they mean a rebuild?
2012 E92 M3 | ZCP | DCT | Space Grey Metallic | Black Novillo | BE/ARP | MPE V2 | AA green filter |BMW CF Rear Spoiler, RW Carbon Diffuser, CF Front Splitters | DTEC 160W Angel Eyes
Jm59008.50 |
07-02-2018, 08:53 PM | #6 |
Rep 39
So I requested the work order from service showing what was done on this “adjustment” the sales rep was talking about and ends up being they Replaced the diff fluid per bmw bulletin that’s what the notes say. Im hoping it’s the cow bell clunk which after reading that thread is very similar to what I was experiencing on the test drive.
PACarGuy683.50 |
07-02-2018, 08:55 PM | #7 | |
Rep 39
What can a rebuild cost at a independent shop any idea? I imagine a rebuild would be worse case scenario? |
07-02-2018, 11:16 PM | #9 |
Rep 39
07-03-2018, 07:11 AM | #11 |
3752
Rep 2,907
Drives: 2011 E93 M3
I wouldn’t describe noisy diff clutches on tight turns as a clunk. It’s more of a repeatable grind than a clunk. Entirely possible that is what you’re experiencing.
Jm59008.50 |
07-03-2018, 07:25 AM | #12 | |
Rep 39
And the turns not tight I was hearing it on 120-130 degree turns coming out of shopping centers onto the far left lane. |
07-03-2018, 08:05 AM | #13 |
Rep 922
I had this problem and I think the dealer changed the diff oil and that was that. It happened on slow right turns.
'11 Black/Black GLK350 (Wife)
'19 Black RAM 1500 Big Horn Night Package '11 Loaded AW Fox Red/Black/Black Carbon Leather ZCP E90 M3 (Halloween Delivery) |
Jm59008.50 |
07-03-2018, 11:55 AM | #14 | |
Rep 39
Dealer changed the oil already and they are telling me the car is now good to go. Just nervous I buy the car and a month from now I need a new diff. How long has it been running without issue? |
07-03-2018, 12:08 PM | #15 | ||
Rep 922
07-03-2018, 02:05 PM | #17 |
Rep 973
Not sure if most shops would take that on but I imagine it's somewhere in the $1-2K range.
Jm59008.50 |
07-03-2018, 03:04 PM | #19 |
3752
Rep 2,907
Drives: 2011 E93 M3
These diffs rarely blow up. The clutches might start slipping but most drivers would never know anything was wrong. Most shops won’t rebuild the oem viscous diff but would upgrade it to something else like an OS Giken at a cost of a few thousand. Replacement used diffs run a grand or so. None of those should be huge issues to someone considering owning an M3. If I were you I’d be more concerned over finding out when or if the rod bearings were replaced.
07-03-2018, 09:02 PM | #22 | |
Rep 39
As soon as I get the car ill have the oil changed and sent over to get checked. I was hoping I could hold off maybe a 2-3 months before doing the bearings but the results of the oil report will dictate that. |
