06-18-2018, 01:46 PM | #1 |
Rep 363
Brake Bleeding Clarification
Hello,
I've changed the brake pads enough times to know that process. Here is my question. I don't know if I will be able to have all 4 wheels off of the car at the same time. What is the correct order of changing the pads and the fluid. Is it all 4 pads first then flush the fluid? Can I do one corner at a time, back passenger pads and fluid then move on the the other three sides? When I am changing the pads I know you have to start the car and pump the pedal a few times, is it necessary to achieve pressure before flushing the fluid? Also, I am using Castrol SRF fluid so I would prefer to drain the reservoir on the car then add new fluid and just use the bleeder as a pressure on the reservoir and not actually fill the bleeder reservoir. Thanks, |
07-06-2018, 12:59 PM | #3 |
mTekMods
2142
Rep 2,901
retract pistons, replace pads, pump pedal then bleed it with ISTA or with the pump method.
2011 Frozen Black/Fox Red E90 M3 650+WHP
G-Power Supercharged First DCT to Manual Conversion Worldwide KW CS, BBS RI-A, BW Headers, Snow 2.5 |
