06-11-2018, 09:17 PM | #1 |
Rep 9
Boot release
Hi guys so got my car towed away and they left the battery on it fully drained now I can't get my boot open to access the battery. Where would the emergency latch be I've pulled out the back seats but can't seem to find it.
06-12-2018, 07:49 AM | #3 |
Rep 1,973
There is none on Aussie cars, you'll have to put a battery tender in the engine bay to charge it up just enough
It's a glaring omission that someone at bmw simply forgot about when designed the f80 rear bench with no ski port and it's boot mounted seat release levers I went through same mental gymnastics when I installed my electric trunk kit thinking if the lock fails, how do I open the boot In the US, they have an emergency trunk release by law, so I installed this with all the oe parts - and yep you'd get to it by removing the side bolster on rear seat and sliding a hook on a long pole into the boot through the opening |
06-12-2018, 09:05 PM | #5 |
Rep 377
Should be as easy as jump starting it from the terminals under the bonnet.
I don't understand how it went flat. I thought everything turns off when it gets too low so that you can still start |
06-13-2018, 07:09 AM | #8 |
Rep 377
06-14-2018, 01:09 AM | #10 |
Rep 1,165
Drives: f83 / E93 335 / E70 X5 40d
Isn't it under warranty? - just get BMW to have it towed to Adelaide Motors and let them fix it.
06-14-2018, 09:21 PM | #12 |
Rep 9
So the full story is i had a little crash and the car got towed to a crash shop they left the ignition on the next day the car got towed to my mechanic they jumped started the car from the cront post no problem when the car got to my mechanic he also had to jump it from the front to get it running after that he put the charger on the front posts and it did not pick up and now its fully dead applying power to the front post does nothing
