06-02-2018, 07:24 PM | #1 |
JDTuning
216
Rep 907
F80 M3 pre & post Meth’ with custom BEF
Hey guys,
Here is a pre & post dyno graph of a F80 with a JB4 tune, high flow catted DPs and stock OEM inlet system running on 98RON pump gas. Peak power achieved before the installation of the Burger methanol injection system and custom remap of the DME (JB4 Map 6 tuning) was around 330rwkW. As you can see, the extra octane and increased IAT suppression achieved a significant gain in peak power with an even greater delta value through the mid range. Please note that I’d fully expect to see 380-390rwkW if the car was fitted with free flowing catless DPs and a high flow inlet system, such as that from aFe or for those that want engine bay bling the super sexy Eventuri carbon fibre kit, lol Also it’s worth noting for those guys who would prefer not to use methanol, a similar result can be achieved with the use of E85 on the stock fuel system and OEM turbochargers of course. Cheers, Justin. Ph: 0421 681 381 Last edited by JD75; 06-04-2018 at 07:29 AM.. Reason: Revision |
06-02-2018, 08:00 PM | #2 |
Rep 1,165
Drives: f83 / E93 335 / E70 X5 40d
wow - can you do that to mine?
06-02-2018, 08:43 PM | #3 |
JDTuning
216
Rep 907
06-03-2018, 05:30 AM | #4 |
Rep 1,165
I have a JB4, catless DP's, Injen intake and Magnaflow midpipe and rear muffler.
I need to get my car to Sydney, don't I, or can someone do it Adelaide? |
06-03-2018, 03:46 PM | #5 | |
Rep 1,885
06-03-2018, 11:13 PM | #7 |
Rep 185
06-04-2018, 01:32 AM | #8 | |
Rep 5,530
It has now made 371kw with the above, plus a custom back end flash and methanol injection. JD75 is estimating another 10-20kw gain by going to catless downpipes and an aftermarket intake. |
06-04-2018, 03:27 AM | #10 | ||
Rep 1,885
Thanks for clarifying. |
06-04-2018, 07:06 AM | #12 | |
JDTuning
216
Rep 907
If you wanted to take things to the next level and upgrade the stock turbos and fuel system for the use of 100% E85 then sure by all means I'd suggest you transport the car to Sydney, but the installation of a Burger methanol injection system is pretty straight forward and your existing mechanic should have no problem handling that. I can also talk you through the back-end-flashing of the DME and the loading of subsequent flash revisions should they be required. Cheers, J. |
06-04-2018, 07:19 AM | #13 | |
JDTuning
216
Rep 907
But the JB4 offers excellent Meth' system integration and for those guys that are keen to use E85 and upgrade their stock fuel system to support high-flow turbochargers port injection control is superior to the hardware used if you have a standalone flash. |
06-04-2018, 07:22 AM | #14 |
JDTuning
216
Rep 907
