05-27-2018, 10:25 AM | #1 |
Rep 100
Need Help! Car Wont Start 2E7C Code!
Alright long story short inlets and outlets are horrible to install. After finishing the install I went to turn the car on and nothing, so I put the car on the battery chargers and its starts going crazy. Everything just flashes and you can hear contractors opening and closing super fast, its like it short circuiting. Car cant start on the charger even after the charger says its charged to 100%. So I take out the jumpers and hook it up to the jeep and right when I put the jumpers on the car acts completely normal, starts right up. When the car finally started I checked the codes and had a 2E7C code.... from what I could find online its generic and everyone thinks its the engine ground stud. So I checked and its not the ground stud, shop says the battery has 12.2v's. At this point if someone gets an idea that fixes the issue i'll venmo or paypal you $50
Also After jumping the car I drove around the block and left it running hoping it would charge the battery and when I shut the car off .000001 seconds after hitting the button the car is completely off like someone pulled the plug out of an outlet. Normally you can shut the car off and yeah hear then engine slowly stop and the lights stay on but this is like flipping a light switch and its 100% dead again. |
05-27-2018, 10:42 AM | #2 | |
Rep 264
05-31-2018, 10:42 AM | #3 |
Rep 3,722
Completely disconnect the battery for at least 30min, put it on a trickle charge, and/or get it tested. Put it back in the car after confirming it's 100% OK and see what happens. Sounds to me like the car needs to relearn something.
Otherwise consider getting a new battery and doing a reset of the battery module. You can do this yourself with a carly or other coding unit, DIY here: http://www.1addicts.com/forums/showthread.php?t=1384864 Or you can bring it to the dealer for them to code a new battery to the car. When you did your inlets, was the car not being used for a while? Is it possible you left a light on or something? Also, driving the car around the block and leaving the car running does literally NOTHING for the battery. You need to be driving for 15+ minutes at highway speeds for any noticeable changes to be made.
"Tobias" 2013 135i ///M-Sport 6MT • Pure Stage 1 • XDI 35 HPFP • 404whp/440wtq |
05-31-2018, 11:39 AM | #4 |
Rep 100
The car will turn on but it its a BSD error and the water pump will only run when the car is in aux mode... when you turn the car on the pump shuts off and the car overheats in the matter of a few min
05-31-2018, 11:57 AM | #5 |
Rep 3,722
Try keeping the battery out for an extended time and get it tested at a dealership. Then put it back in once you've verified that it's 100%. Or see if you can "borrow" a new one to test.
06-01-2018, 09:48 AM | #6 | |
Rep 264
Also obviously unplugging those items will give you a different fault, but you are looking for the fault that you currently troubleshooting to go away, and the water pump to work normally. |
06-01-2018, 02:09 PM | #7 |
Rep 100
I just got a new battery even after them telling me its fine and it now starts..... I never touched the water pump so I don't know why I would be bad. I'll try unplugging each thing tonight.
The water pump cycles for like 30 seconds when I open a door, trunk or pop the hood..... |
06-01-2018, 09:37 PM | #8 |
Rep 893
These cars go apeshit when the battery begins to fail. Your car is fine.
2011 135i MSport 6MT AW/black, 72Kmiles, bone stock, moneymoneymoneymoneymoneymoneymoneymoneymoneymoney I LOVE THIS CAR
06-02-2018, 01:44 PM | #9 | |
Sideways and Smiling
3027
Rep 2,860
Drives: In Exuberance
2012 BMW 328i 6-Speed Wagon | Deep Sea Blue with Grey Dakota Leather | Manual Swap, 330i Intake + Tune, 3.15 Helical LSD, Öhlins R&T
(SOLD) 2009 BMW 128i 6-Speed Coupé | Monaco Blue with Black Sensatec | chris_flies' 128i thread |
06-04-2018, 07:15 AM | #10 |
Rep 100
No I have the hood up and to make sure I took the cap off the coolant bottle and you can see it circulating water.... I'm mostly concerned with trying to load tunes off MHD if there is a communication error I really don't want to brick the car.
