05-12-2018, 03:20 AM | #3 |
Rep 8,364
I am not a huge fan of the reflectors, but LED sidemarkers are so subtle. Plus, there have been multiple studies that say drivers response time is better in seeing vehicle.
05-12-2018, 06:59 AM | #4 | |
Rep 1,973
Since the sidemarker illuminates only with headlight main beam on, I can't see how an orange side marker makes the car more noticeable at night than having headlights on lol |
05-12-2018, 06:09 PM | #5 |
Rep 8,364
There have been studies on it. I cannot seem to find post at the moment.
05-13-2018, 01:38 AM | #7 |
Rep 1,973
05-13-2018, 07:23 PM | #8 |
Rep 5,316
Drives: G80 M3 6MT
I highly doubt that is something that you'd get pulled over for, let alone ticketed.
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
Whatcoloristhat66.50 |
05-16-2018, 02:31 PM | #9 |
Rep 286
Is there a cheat guide for this app? Not trying to read german lettering and numbers and guess what they correspond to. I have the software for a laptop but my macbook is acting up and will not boot bootcamp so just might have to pay for this app if its idiotproof and has the same offerings as the laptop software.
05-16-2018, 10:37 PM | #10 |
Rep 1,973
Afaik this hasn't been cracked in 'laptop coding' for the led, only bixenon
Hence the need to post this up and give BimmerCode a pat on the ol back |
05-17-2018, 04:46 PM | #11 | |
just a fool
345
Rep 675
Coding for Xenon: http://f80.bimmerpost.com/forums/sho...17&postcount=5 Coding for LED: http://f80.bimmerpost.com/forums/sho...44&postcount=7 |
12-23-2020, 01:40 AM | #12 |
Rep 2,418
Hello
Bumping an old thread. I tried to disable sidemarkers on 19 M4 CS. Although I saw the option in bummercode and it was already noted for, they did not turn off. I tried both turning off sidemarker and even turning off in brightness. Any ideas what's going on? |
12-23-2020, 04:35 AM | #13 |
BimmerPost Supporting Vendor
1790
Rep 3,056
In 19 you need to disable in FLE modules.
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
12-23-2020, 06:05 AM | #14 |
Rep 4,203
What is exactly next by "19"
I was told by a remote coder mine could not be disabled. Early build MY 07/14 full LED but some software files had been updated by previous owner. Per this I was told they could not be coded out...... HAs there been a change? I have the bimmercode app |
12-23-2020, 06:49 AM | #15 | |
1790
Rep 3,056
12-25-2020, 01:57 AM | #16 | ||
Rep 548
12-26-2020, 11:00 PM | #17 |
M3MBER
75
Rep 129
Drives: F80 M3 -Yas Marina/Silverstone
To Code with BimmerCode app (in Expert Mode).
For older F80's with TMS Modules (Left & Right) TMS_03 (Driver Headlight Module left): >Section 3005 -Standlicht Modus 1 -Standlicht Modus 2 -Welcome Light 1 (if you want the 3 LEDs off when unlocking). TMS_03 (Driver Headlight Module right): >Section 3005 -Standlicht Modus 1 -Standlicht Modus 2 -Welcome Light 1 (if you want the 3 LEDs off when unlocking). Stock (On) Amber LEDs: 00, 03, 00, 00, 64, 03, 00, 00, 64, 03, 00, 00, 2B, 04, 00, 00 change the Werte Value from 64 to 00 as follows: Coded (Off) Amber LEDs: 00, 03, 00, 00, 00, 03, 00, 00, 64, 03, 00, 00, 2B, 04, 00, 00 Make this same change to all sections mentioned above (Standlicht Modus 1, Standlicht Modus 2, and Welcome Light 1) For newer F80's with FLE instead of TMS, then use these steps instead: Front Light Electronics (FLE) Left - Navigate to Front Light Electronics Left - Click on Expert mode - Click on 3006 LED1 - Click on LM_ID_LT4 - Change to 02_VALUE / 0x00 - Go back to the 3006 LED1 page - Click on LM04_NAME - Change to 02_VALUE / 0x00 - Back on 3006 LED1 page and click code Check & verify if value changes worked for the Left headlight. If no-go, revert back. If good, then proceed with the Front Light Electronics Right control unit. Front Light Electronics (FLE) Right - Navigate to Front Light Electronics Right - Click on Expert mode - Click on 3006 LED1 - Click on LM_ID_LT4 - Change to 02_VALUE / 0x00 - Go back to the 3006 LED1 page - Click on LM04_NAME - Change to 02_VALUE / 0x00 - Back on 3006 LED1 page and click code
2015///M3|Yas Marina Blue|Silverstone|
regpaq73.50 |
12-27-2020, 04:45 AM | #18 | |
Rep 4,203
12-27-2020, 03:08 PM | #19 |
M3MBER
75
Rep 129
Yes, it will work. Your coder is mistaken
03-30-2021, 09:56 PM | #20 | ||
Rep 645
Thank you for sharing this! FLE worked for me with e-sys. 2018 M3 with Adaptive LED headlights |
06-30-2023, 05:36 PM | #21 | |
Rep 99
