05-05-2018, 08:23 PM | #1 |
E82 Mudflap Ambassador
2214
Rep 2,219
Drives: '08 128i
"Help me fix my suspension over the internet" thread
Not super concerned right now just wanna hear input. Symptoms started happening one day, it wasn't really a progressive thing.
So my steering wheel is vibrating a wee bit above 50mph and my steering isn't as sharp - actually it seems like it wants to tramline sometimes. Little bit of tramlining, little bit of 'itll "lean" to one side and pull that way' which sounds like alignment (probably is a bit lol) but it can track straight most of the time. Vibrations don't really vary with speed, seems like it vibrates at the same frequency regardless. Maybe a wheel weight flew off. Honestly I'm thinking it's a mix of worn control arms/tension rod bushings, probably needs an alignment, whatever tires these wheels came with are cupping or heat cycled (they're pirelli pzeros, not dry rotted out work but def aged) Anyone deal with something similar? Feel free to share your worn suspension findings below too
My 2008 128i - Sparkling Graphite/Beige - Sport pkg - 6MT - Click me!
Parents' 2014 528i - Mineral White/Ivory White - fully loaded Instagram @Andreys_128i and @Honda.Bito |
05-06-2018, 10:38 AM | #2 |
shmo
383
Rep 1,026
lol i got a good one for you..
17 stocks.. car pulls right.. 18s 264's.. car pulls right.. aligned at dealer .. car still pulls right.. 17 front(same 2 when it pulled right before) and 18 264 in rear.. *** car doesn't pull right*** I'm guessing theres something loose on passenger side as the car is pitched forward due to 17 front 18 rears and is is keeping the loose part in check.. or it could be a gremlin in the right tire.. idk.. couldn't diagnose ur prob.. figured id share my pain!! if u find out what ur deal is.. keep me updated
No sig
desertman1232213.50 |
05-06-2018, 01:48 PM | #3 | |||
Rep 3,549
Wheel out of balance. One of the front ones at a minimum. Quote:
Eh, if it just happened, and / or only certain roads, I wouldn't get too worried about this stuff yet. Start w/ the basics, check the tires, maybe rotate them, and definitely get them balanced at a GOOD shop. Go from there after that, odds are this will identify the issue. |
05-06-2018, 03:58 PM | #4 |
Malcontent
188
Rep 305
How many miles on the suspension? I just inspected mine at 115k miles (trying to track down a light clicking, probably a ball joint starting to go) and the bushings are DONE. Like easily deflected by grabbing the arm and twisting done. Dead bushings will allow all sorts of uncontrolled movement, and they aren't going to resurrect themselves.
Ordered a new M3 suspension package. Best to do it all, do it once, and move on.
Life's tough. It's tougher when you're stupid. -John Wayne
05-06-2018, 04:41 PM | #5 | ||
2214
Rep 2,219
Drives: '08 128i
I'm leaning towards tire out of balance - the vibrations are still pretty miniscule so that's probably why I can't feel it change frequency. I rotated the fronts today and it's slightly better but not a huge difference. I'll look into getting the wheels balanced at a reputable shop. Quote:
The sway bar end links could pivot a bit but it felt normal- both by the same amount and they weren't sticking or anything Definitely going to look into replacing it - along with just getting coilovers
Parents' 2014 528i - Mineral White/Ivory White - fully loaded Instagram @Andreys_128i and @Honda.Bito Last edited by desertman123; 05-06-2018 at 04:49 PM.. |
05-06-2018, 06:07 PM | #6 |
1Addict
3234
Rep 7,894
Two issues to look at. First, your toe is out. Of it tracks straight sometimes and tramlines others, that should be alignment and road conditions. Second, funky balance on wheels. Steering wheel is front, vibration under load in seat is rear. I was chasing this bad vibration and roar under load for a while until I actually looked at the wheels, a tech had messed with my wheel weights and they were haphazardly stuck all over. Scraped them off new balance, and fixed it 100%.
Do you get bump steer?
05-06-2018, 06:41 PM | #7 |
Malcontent
188
Rep 305
You can try taking the load off the bushings by lifting the hub to normal ride height, but even extended you'll likely find there's play in them. Grab a prybar and start poking around.
If you're doing other work (coilovers), you definitely want to refresh the bushings and ball joints.
05-06-2018, 06:54 PM | #8 |
C2H5OH
3915
Rep 2,144
Turn traction full off and retest.
With my car freaking out over my ABS debacle I am driving with no driver aids other than ABS. So my DSC is FULL off (not just button off) as is the E-diff. What I'm finding is the car drives fantastic on good roads. But any road with crown it will pull. Same roads previously with working car I never noticed. That to me is saying the DSC is far more active than a guy realizes. To add to this, when I go from Winter tires to Summer (with working car) I always notice about a week (100 miles or so) where the car just feels weird. I'm pretty sure it's the DSC relearning the rev/mile and adjusting to keep the car on track. It's the only logical explanation I can come up with. What I'm saying is it may be nothing wrong with suspension or wheel or weight. It might just be the car going through a learning phase if new tires have been put on or there is a rolling diameter change. |
05-07-2018, 09:14 AM | #9 |
Sideways and Smiling
3027
Rep 2,860
Drives: In Exuberance
I'd point you towards two things:
Alignment. It's amazing what a correct alignment makes the car feel like! It's also amazing how bad a car can feel with a bad one... Front Control Arms. Replacing the front control arms fixed a shimmy like the one you describe on both my car and my father's former E39. M3 ones also tighten-up the steering feel and almost make it ride better...
2012 BMW 328i 6-Speed Wagon | Deep Sea Blue with Grey Dakota Leather | Manual Swap, 330i Intake + Tune, 3.15 Helical LSD, Öhlins R&T
(SOLD) 2009 BMW 128i 6-Speed Coupé | Monaco Blue with Black Sensatec | chris_flies' 128i thread |
05-07-2018, 10:28 AM | #10 | ||
2214
Rep 2,219
Drives: '08 128i
Barely any bump steer, if at all. I figured it was mainly the front wheel balance - like I said I had a chance to swap them around. Helped a bit but only really masked the issues. Quote:
Thanks for the advice guys. I'm doing my AC compressor pulley/bearing today so while the car's in the air (easiest to just remove the AC fan and alternate between the top and bottom) I'll inspect everything thoroughly, and have a reputable shop give everything a balance.
chris_flies3027.00 |
05-07-2018, 11:33 AM | #11 | |||
3027
Rep 2,860
I still need to write the instrument cluster DIY, too. Oops.
