04-27-2018, 08:40 PM | #1 |
Rep 55
Rattling mostly and a little grinding MT
Shop says coming from the rear of the transmission on my 2011 135i MT. I bought the car from a person on the forum a few months ago and the rattle seems to be getting worse as time goes on. A couple questions for the experts here, would the bearings on the rear output shaft be changeable in the field or would it be best to find a used transmission and change it out??
Also is there a "model number" of the trans to help locate what is available?? Any one else experience a similar situation? Has 105k on it now. Thanks!! Greg |
04-27-2018, 09:04 PM | #2 |
Sideways and Smiling
3027
Rep 2,860
Drives: In Exuberance
Is it a chugging sound, like a low rumbling when in neutral with foot off of clutch? That's usually just clutch chatter, which is mostly harmless...
A clunking when setting off is usually indicative of an aging Dual Mass Flywheel, but can also be a failing Guibo joint (very close to trans' rear) or driveshaft center support bearing (under rear sear floor). I haven't seen any issues with tranny bearings, but I'd definitely look more into it, it would suck to replace the trans and find out that it was a center support bolt that was slightly too loose. About the bearings being serviceable, I have no idea about that! Good luck! I hope you find an easy, inexpensive solution to your issues!
2012 BMW 328i 6-Speed Wagon | Deep Sea Blue with Grey Dakota Leather | Manual Swap, 330i Intake + Tune, 3.15 Helical LSD, Öhlins R&T
(SOLD) 2009 BMW 128i 6-Speed Coupé | Monaco Blue with Black Sensatec | chris_flies' 128i thread |
04-28-2018, 06:55 PM | #3 |
Rep 55
A bit more clarification...
Seems to start making noise around 20 mph, none of the following seem to matter... what gear, brakes, clutch in or out. What does seem to matter is pulling hard seems to make it either quit or be less "hearable"??? Can't seem to hear it at 40 or so plus, maybe due to wind and road noise...
Appreciate you taking time to answer!!! Greg |
04-28-2018, 07:18 PM | #4 | |
Rep 8,165
Have someone in the car, get it on the lift and listen to the gearbox and driveshaft area from underneath the car.
chris_flies3027.00 |
04-29-2018, 06:28 AM | #5 |
Rep 55
Good description!
We have that planned, had the walnut blasting done and ask the shop to look into it and they say it's coming from rear of trains but will confirm!
04-29-2018, 09:30 AM | #6 |
I like turtles!
726
Rep 698
Let me get my chrisflies comment out of the way-- "OP, should've bought a DCT so you wouldn't have this problem! DCT for the win!LOLBAGOFDICKS!!11!" Oh, wait...
With that out of the way, take the car to the dealer. Yes, they'll charge you an hour labor to check it out, but you'll know for a fact what the issue is. My feeling is that you need a new transmission, since these are not rebuildable due to the fact that they don't sell parts for them. |
04-29-2018, 12:08 PM | #7 | |
3027
Rep 2,860
04-29-2018, 08:06 PM | #8 |
Rep 55
Well, my other one is a DCT!!
Hate to hear that they don't sell parts!! That sucks! Advise of going to the dealer is good though!
Have a feeling this was known when I bought it from the last owner, sad!! Thanks all for the comments!! Greg |
