04-22-2018, 10:50 AM | #1 |
Rep 33
STUCK...need help!
Went to get the 2013 135i out of storage for the Spring and someone unplugged the battery tender. Got a slight charge and she started but threw the gear with explamation point light on the dash and won't go into gear. She was in tip top when we went into storage...any ideas?
04-22-2018, 11:03 AM | #2 |
Rep 2,276
Fully charge the battery then try again.
Matticus913474.50 jaye9441014.00 |
04-22-2018, 11:15 AM | #4 |
Rep 3,241
No.
04-22-2018, 11:28 AM | #5 |
Malcontent
188
Rep 305
Depending on the age of the battery, full discharge may have killed it. First try to get a full charge into it and see what happens. If you can't get it to hold in normal use, replacing the battery will be necessary.
Life's tough. It's tougher when you're stupid. -John Wayne
04-22-2018, 12:41 PM | #6 |
Rep 3,722
You wouldn't lose your tune from a flat battery, it's not the same electrical module that gets reset like the clock/date etc.
Just try a full charge and if it doesn't hold get a new battery. Then stab whoever unplugged it
"Tobias" 2013 135i ///M-Sport 6MT • Pure Stage 1 • XDI 35 HPFP • 404whp/440wtq |
04-22-2018, 02:38 PM | #7 |
Rep 33
Yeah...plotting the stabbing now. Limped her home and she's going to sit on a charger for a day or two. Got enough juice to get her started and out of storage and home. Everything programmed stayed (HomeLink, Iphone pairing, etc.). Wish me luck...any idea what battery replacement runs $$ ?
chris_flies3027.00 |
04-22-2018, 02:59 PM | #8 |
Rep 341
Coding is an hour of dealer labor plus the cost of the battery. Not sure if coding is absolutely necessary if the replacement is of the exact same amperage, size, etc, or the same one. I have yet to do this on mine and would like to see how it goes...
Metallic Black on Black 2009 135i, new waterpump, OFHGs, and VC gasket...RB turbo PCV valve (ooo), NGK performance plugs...V3Cobb access port stage 2+FMIC, Injen intake, Mishimoto clone FMIC, ARM charge pipe, ARM downpipes, Whiteline subframe bushings
04-22-2018, 04:21 PM | #10 | |
Apprentice
373
Rep 801
Programmed the battery using Carly. |
04-22-2018, 04:32 PM | #11 |
Rep 334
Check it out?
http://www.1addicts.com/forums/showthread.php?t=1487179
BTW, get a CTEX battery maintainer. I recommend the 7002. You can get it off Ebay. |
04-22-2018, 05:51 PM | #12 |
Rep 3,241
The registering of the battery is necessary because BMW got all fancy and set up charge cycles based on the age of the battery. You can reduce the service life of a new battery if you don't go through the process of getting it registered.
04-23-2018, 08:21 AM | #13 |
Rep 3,722
Here's a thread I did on battery replacement using Carly
http://www.1addicts.com/forums/showthread.php?t=1384864
04-23-2018, 03:48 PM | #14 | |
Beachtown Bill Collector
582
Rep 1,062
Drives: 2012 135i
Esteban43791.50 |
04-23-2018, 04:26 PM | #15 |
Rep 2,276
You mentioned battery tender so I assume you have a Deltran battery tender. It may take a week to get your battery back up to 100%. I think CTEK also have low outputs too ( 1 amp to 2 amps). Schumacher also make very good units. I would try and get a "battery charger" from Schumacher that puts out 6-10 amps.
Don't know how far you are from Milwaukee (I may have asked this before) but I know a woman in Milwaukee who knows BMWs (especially older ones) inside and out. |
04-23-2018, 04:48 PM | #16 | |
582
Rep 1,062
Drives: 2012 135i
04-23-2018, 05:23 PM | #17 | |
Rep 33
04-23-2018, 07:47 PM | #19 | |
Rep 334
I own two, 3300 and 7002. They have saved me many times getting a dying battery up. In fact, one has been on my Mercedes, my summer ride, all winter. |
tock172581.50 |
04-23-2018, 08:37 PM | #20 |
582
Rep 1,062
Drives: 2012 135i
Nice setups. I've got a 3300 that's maintaining the 135i as I type this and I just ordered the MUS 4.3, which was also sold as the BMW branded version.
