04-13-2018, 07:49 AM | #1 |
Rep 141
High Mileage - To Buy or Not To Buy?
Hi everyone,
So I’m in the market for a 135i 6MT and came across a 2011 with 130k on the clock for $11.5k. M Sport package, Nav, but no heated seats (which I actually did want). Seller states he has full service records and has recently done the water pump, walnut blasted and changed the battery. 2 questions: First, should I reconsider purchasing a car with this mileage? Secondly, if still recommend, what are some likely points of concern that I should look for? I’ll be taking the car in for a PPI at a reputable shop near the seller and wanted to make sure I’m as informed as possible on what I should expect. Thanks! |
04-13-2018, 08:34 AM | #2 | |
Sideways and Smiling
3027
Rep 2,860
Drives: In Exuberance
Suspension-wise, you'll definitely want/need to do some fresh bushings on it, as the basic ones wear quickly and ruin the handling and ride of the car. Engine-wise, it sounds like it has had the big-ish stuff taken care of. Definitely have a PPI done, I didn't, but the dealer still replaced a cracked power steering cooler before delivering it, for free, which was awesome. I'd look for oil leaks on the oil filter housing, valve cover gasket, and oil pan since they're all common leak locations. Check and see if the high pressure fuel pump was replaced, as those are nearly guaranteed to say "auf wiedersehen" at some point. There's a lot of information you can find here, as we are a pretty supportive and engaged community. Really, just be sensible, and don't get attached to the car (I did, but regret nothing) as it could lead to a bad decision... Hope to see another new-to-someone 135i!
2012 BMW 328i 6-Speed Wagon | Deep Sea Blue with Grey Dakota Leather | Manual Swap, 330i Intake + Tune, 3.15 Helical LSD, Öhlins R&T
(SOLD) 2009 BMW 128i 6-Speed Coupé | Monaco Blue with Black Sensatec | chris_flies' 128i thread |
04-13-2018, 09:00 AM | #3 |
Rep 7,224
chris_flies gave some solid advice. Check this thread for a lot of helpful info. PPI is a definite must do. Good luck.
chris_flies3027.00 |
04-13-2018, 09:31 AM | #4 |
I like turtles!
726
Rep 698
I would see all the service records available and go from there. Generally speaking, if the oil has been changed every 5-7k, hasn't been overheated, hasn't been modified by a kid and put back to stock and isn't grinding 3rd gear, you'll be fine. What are your expectations of the car?
04-13-2018, 09:49 AM | #5 |
BMW Cool Aide!
903
Rep 841
I was recently looking at 135i cars, and that price is a bit high for the miles. I found under 80K 135i's for $12K. But maybe they all sold.
04-13-2018, 10:29 AM | #6 |
Rep 141
chris_flies Thank you for the thorough reply! Much appreciated.
Esteban Thanks for the link, first time I see it. captain slowly My expectations are for it not to need a $xxxx repair anytime in the near future haha. JimVonBaden I've been hunting for about a month or so and I would say you are correct to some extent. Automatic convertibles are bottom of the totem pole and can easily be found in that price range or less for under 100k miles. As you move up into manual convertibles, auto coupes and finally manual coupes they tend to move up in price due to supply and demand - not to mention enthusiasts typically will hold out for what they truly believe the car is worth. Also while this particular 135i is not the color I was looking for (LeMans Blue) it is what many consider the "best" combo of Alpine White/Coral Red which adds the exclusivity tax. |
04-13-2018, 10:40 AM | #7 | |
BMW Cool Aide!
903
Rep 841
04-13-2018, 10:45 AM | #8 |
Rep 1,011
All depends on what your budget is, but if the maintenance records are solid and the car is in good shape and you want it, go for it.
I tend to be the opposite when it comes to used cars with higher maintenance requirements, I will pay a premium for a lower, mileage flawless car that won't need the maintenance for awhile. Of course, I purchased my '13 135i 3 months ago with 26k miles on it, and drove it back from 800 miles away. And now at 28k it sounds like it needs the tensioner pulley and belt. Dammit! |
04-13-2018, 10:45 AM | #9 |
Rep 545
Agreed that the price seems a touch high, but the N55's do seem to go for more than N54's with similar mileage
2011 BMW 135i ///M-Sport, DCT
Bilstein B12 kit, Dinan camber plates, M3 front control arms, Whiteline poly RSFB, MHD Stage 1, cp-e Charge Pipe, H&R Front sway bar, BMW performance diffuser |
JimVonBaden902.50 |
04-13-2018, 01:29 PM | #10 | ||
Rep 141
The way I see it, paying 50% more isnt worthwhile assuming they have been equally maintained. Now I could be totally wrong and come back a month later crying about my high mileage woes but seeing as there haven't been any "run for the hills" replies, I'm hoping I'll be safe. Quote:
04-13-2018, 01:49 PM | #11 |
Rep 904
Just to use as a datapoint, I recently bought a 2012 135i M-Sport manual w/o Nav with 38K miles from Carmax for $19,990, and they're not exactly known as being the best deal in the world. I bought from them because I could add the MaxCare warranty.
04-13-2018, 02:03 PM | #12 |
Rep 341
At least you know its not a lemon...
Metallic Black on Black 2009 135i, new waterpump, OFHGs, and VC gasket...RB turbo PCV valve (ooo), NGK performance plugs...V3Cobb access port stage 2+FMIC, Injen intake, Mishimoto clone FMIC, ARM charge pipe, ARM downpipes, Whiteline subframe bushings
duder13767.00 |
04-13-2018, 02:26 PM | #13 |
Rep 2,276
I think you'll be good. I always prefer private sales, records and PPI. Another easy point of reference is what tires he has on car; MPSS very good, Wang Ho Super Track, not so good.
04-14-2018, 06:24 AM | #14 |
I like turtles!
726
Rep 698
04-14-2018, 06:33 AM | #15 |
I like turtles!
726
Rep 698
funny, but I judge cars the same way. Ling Longs or hankooks on there? Yeah, I'm gonna go ahead and assume that everything else was taken care of the same way; cheapest way possible or not at all.
04-14-2018, 05:56 PM | #16 | |
Rep 439
Buyers of new 911s will get the PDK Coupe or PDK Cab. Enthusiasts look for the second hand manual coupes once they’ve dropped in price. |
JimVonBaden902.50 |
04-19-2018, 07:44 AM | #17 |
Rep 334
A Waste of Money!
What's the typical lifetime of these cars? You are paying a high price for the remaining mileage left in this buggy. And a car with this mileage will have problems with shocks, springs, and other suspension parts wearing out besides the known problems these cars have.
I'd bet money you'll spend at least the amount of money you paid for the car in repairs as the car ages towards its final demise. Add another $9K or slightly better and you easily find a much lower mileage car. BTW, I've been buying and selling cars for years, and I've never found service records to be of much value. The only thing worthwhile is an inspection by a competent mechanic. I have one I've been using for years, so I seldom get stung. Finally, I'll tell you what this car is worth, around $4k. |
04-19-2018, 08:27 AM | #18 | |
BMW Cool Aide!
903
Rep 841
Every car is different based on its maintenance history. Lots of modern cars easily exceed 200K miles.
Esteban43745.00 chris_flies3027.00 |
04-19-2018, 10:15 AM | #19 |
Bowties r cool ▶:◀
1409
Rep 796
Drives: 09' 128i MT e88, 24'G05 X5 50e
Unless this car has a salvage title it still is prob worth more then $4k.- who let the bag of sourpuss in?
If you would like a list of what a car like this have gone thru the auctions as of late, I have some connections.- see thats how this works in the spirit of 1Addicts Last edited by Tuxedo; 04-19-2018 at 10:29 AM.. Reason: spelling eerror?s |
04-19-2018, 10:34 AM | #20 |
Rep 704
Generally speaking, i never shy away from a high mileage car IF all the records prove the work. Would you walk away from say a 200K mileage car that has all the "usuals" just replaced 1K miles ago? including new brakes all round, tires, fluids etc?
But it does not have heated seats, not sure where you live but here in Bavaria Germany, it is a no brainer, BMW heated seats are OP. Turn them on and 3 minutes later your bum is on fire, they are one of the best in the business in this department. I have seen bone stock BMW engines last 300,000 kms on the Nordschleife. That is 300,000 kms redlining, nothing but an oil change every 5,000kms/season. So apply that logic (as long as maintenance is done correctly) to any car. I have personally achieved 373,000kms on our 96 bmw 328is, service was done every interval. Yes we went through 3-4 water pumps, lots of tires and brakes, a few belts and some sensors, but mechanically there was nothing wrong with it. |
JimVonBaden902.50 |
04-19-2018, 03:23 PM | #21 | |
Rep 334
BTW, I buy cars all the time through public and dealer auctions. If it had a salvage title, it'd be worth zip. In the public auctions, the bidders often pay way too much. |
04-23-2018, 11:49 AM | #22 |
Rep 141
