04-02-2018, 11:49 AM | #1 |
Rep 28
Squeaking belt? I've tried lots of suggestions from Forums.
Been trying for weeks to get this noise to stop and it keeps coming back. I've read threads here and have done the following within the last 2,000 or so miles:
Brand new OEM alternator Brand new OEM Serpentine Belt Brand new OEM Tension Pulley Brand new OEM Deflection (3 IIRC?) pulleys Replaced OFHG Removed belt and deep cleaned all pulleys and belt with a brush and water When you check out the below videos some things to note: 1. The sound gets worse at higher RPM's, is almost nonexistent or slower at idle 2. When I take off the belt and clean it the noise goes away; most recent scenario was yesterday, I took the belt off and cleaned everything in the morning, put the belt back on the car, drove 40 miles to visit family with little to no squeak, drove back 40 miles and once I'm home I took the below videos. It was very loud at this point. 3. When I replaced the OFHG a month ago, I replaced the serpentine belt and pulleys at the same time; after replacing the OFHG I cleaned all oil residue from the leak. Yesterday when cleaning the belt, there was no evidence of a new leak. What I think could possibly be wrong: 1. I was sold a bad pulley or tensioner from ECS Tuning 2. There is some way that oil or some fluid is getting on the belt that I am oblivious to, the only pulley that I am not able to get to to clean 100% is the Crank pulley which doesn't freely spin at the very bottom of the engine. 3. Radiator fan squeaking? Also, ignore the CEL in the second video, it is a wheel speed sensor that is on its way to me to replace this week as well. Man aren't these fun little cars ! |
04-02-2018, 12:58 PM | #2 |
Rep 1,119
Its a crack in your valve cover, willing to bet money on it
chris_flies3027.00 |
04-02-2018, 01:18 PM | #3 |
Sideways and Smiling
3027
Rep 2,860
Drives: In Exuberance
That would be a reasonable diagnosis!
OP, I'd also make sure all of your OFH bolts are tightened correctly, the ones holding the oil cooler adapter into my new housing weren't tightened when I got it and it was dripping oil onto the belt, which then flung oil everywhere in the engine bay. Much fun to clean...
2012 BMW 328i 6-Speed Wagon | Deep Sea Blue with Grey Dakota Leather | Manual Swap, 330i Intake + Tune, 3.15 Helical LSD, Öhlins R&T
(SOLD) 2009 BMW 128i 6-Speed Coupé | Monaco Blue with Black Sensatec | chris_flies' 128i thread |
T_EV16.50 |
04-02-2018, 01:32 PM | #4 |
Rep 28
Is this a common issue with the N55's? You sound like you've gone through this before. Do you recommend replacing just the gaskets for 50$ or the entire Valve cover for ~ 500$ diy?
It would help if I could see an active leak or if there is a way to detect an active leak. I cleaned everything up really good last time I had it all apart and there is no oil residue anywhere. Also, finding a few DIY videos on the N54 job which looks very intimidating, but none on an N55. Any DIY vids out there for the N55? Last edited by T_EV; 04-02-2018 at 01:50 PM.. |
04-02-2018, 02:05 PM | #5 | |
Rep 1,119
http://www.e90post.com/forums/showthread.php?t=1197666 Sure enough, solved the issue. I don't think it looks like that difficult of a DIY. Only reason I didn't tackle the project is because he barely charged me on labor due to the misdiagnoses. From what he said, luckily my seals were still in good shape. Hope that helps. |
04-04-2018, 08:24 AM | #6 | |
Rep 28
From the above thread: 'If you have any reason to suspect PCV system malfunction, first open the oil cap to see if the problem (e.g. main seal noise) immediately subsides' Tried this last night, noise immediately stopped, tightened/sealed the oil cover cap and the noise started again. Glad to know what the problem is. I assume that at this point in time I just need to bite the bullet and 1. buy this: https://www.ecstuning.com/b-genuine-...r/11127570292/ 2. Do the plugs/ignition coils while I'm at it. (is this necessary?) 3. Drive away into the sunset until and have no more problems for another 100k miles? Am I missing anything? Also, am I safe to drive for a few weeks? Funds are low after the 1200$ starter job from a week ago. Last edited by T_EV; 04-04-2018 at 09:47 AM.. |
04-04-2018, 10:15 AM | #7 | |
Rep 1,119
For what it’s worth, I drove with that noise for almost a month before I had it taken care of. |
T_EV16.50 |
04-04-2018, 03:31 PM | #8 | |
Rep 28
Currently: Noise started a week ago 72,200 miles No tune Round trip to work each day: Back roads less than 8 miles round trip. I don't get above 50 mph. I've never replaced plugs and have no way of knowing if they've been replaced (other than taking them out and looking) I plan on 100% doing the plugs but are the ignition coils necessary to replace. I'm going to do it if I find oil that has made its way past the seal but if they look fine are they a wear item that needs to be preventatively replaced or are they fine for the life? |
04-04-2018, 05:14 PM | #9 |
Rep 1,119
Can’t speak for the ignition coils. I’m at 76k and had the plugs replaced when I bought it at 50k. I’d only do the plugs if I were you.
I also had my starter replaced not long ago like yourself. These cars can be a pain, but they’re great when they work |
04-04-2018, 06:40 PM | #10 |
3027
Rep 2,860
They wear, especially when you have bad plugs. The DME (ECU) makes adjustments when spark plugs aren't 100%, which usually consists of working the coils harder, compensating for worn plugs. Very cool thought, but it masks bad plugs, and gives you much more to replace when something does go kaput...
04-05-2018, 09:00 AM | #11 |
Rep 3,722
Didn't have the time to read the whole thread so apologies if someone mentioned this already - sounds like it could be the power steering pump, have you tried checking it/adding fluid?
Start with the cheap stuff and work your way up....
"Tobias" 2013 135i ///M-Sport 6MT • Pure Stage 1 • XDI 35 HPFP • 404whp/440wtq |
04-06-2018, 09:24 AM | #12 | |
Rep 28
04-06-2018, 09:58 AM | #13 |
Rep 28
This is the first time I've seen this come up. I was 100% sure it was the Valve Cover Gasket or more specifically the PVC valve which is built into the VCG because when I take the oil cap off which depressurizes the system, the noise immediately quits, seal the oil cap back on... Noise starts again. I will, however, check the PS fluid tonight JUST in-case, thanks for the suggestion!
04-06-2018, 10:58 AM | #14 | |
Rep 3,722
04-06-2018, 12:57 PM | #15 | ||
3027
Rep 2,860
04-12-2018, 08:49 AM | #16 |
Rep 28
*** UPDATE ***
Took it to the shop (local Indy been there 25+ years, 4,000 reviews on Google, 4.9 stars) for a second opinion before I tore the car apart to replace the Valve Cover. Tells me it's the AC Compressor and he's 100% positive. Quotes me $2,200 to fix. He only uses OEM parts in order to provide a 2 year warranty on parts & labor. OEM AC Compressor is $1,500. So going from here, I have three options: 1. Pay $2,200 bringing my total repair costs in the last 3 weeks to $3,500. I have the money but would have to dip into savings and my wife would probably kill me in my sleep. 2. DIY. Buy an aftermarket AC Compressor (link below) and get someone to professionally remove the freon, and then re charge after the work is done: Cost: $350 for the part, $150 for AC System removal/recharge. Save $1,700. 3. Buy the Aftermarket Denso unit and get the shop to install it. He said he would do it but couldn't warranty the labor. Cost: $1,200; Save $1,000. I'm leaning towards #2 because the job is pretty easy from what I can tell, especially with getting the freon or refrigerant (whatever the correct term is) removed at a shop. Does anyone have any opinions about aftermarket options like the link below ($350) vs OEM that fails at 70k miles ($1,500)? I've seen the DIY on the threads but it's an N54. I'm pretty mechanically inclined, I was going to DIY the valve cover job and was confident in my abilities. Another note, I've seen something about oil in the AC compressor? Something about checking oil levels before and replacing oil when you put a new AC Compressor in? Any ideas? https://www.autozone.com/cooling-hea...19_153838_3513 |
04-13-2018, 08:21 AM | #17 |
Rep 545
Based on your previous test where the noise stopped when you removed the oil cap, I highly doubt that the AC compressor is at fault. If the compressor was failing, why would the noise stop when you remove the oil cap? If you really want to be sure, I'd try to get a third opinion.
2011 BMW 135i ///M-Sport, DCT
Bilstein B12 kit, Dinan camber plates, M3 front control arms, Whiteline poly RSFB, MHD Stage 1, cp-e Charge Pipe, H&R Front sway bar, BMW performance diffuser |
04-13-2018, 08:40 AM | #18 |
3027
Rep 2,860
About the oil in the compressor:
As far as I know, it's not necessary, or even possible, to check the levels in our cars. I do know that modern refrigerant, sold everywhere, contains lubricants, anti-corrosion agents, and conditioners inside them to keep your A/C system maintained and healthy. I agree with BimmerAg , though. After your oil cap test, I seriously doubt it's your A/C compressor that's at-fault. Bad A/C compressors either lock up entirely and cause belts to melt, or make some other kinds of God-awful sounds that you'd definitely know. Plus, the A/C wouldn't work, and you'd notice that...
04-13-2018, 09:00 AM | #19 |
Rep 6,196
If the noise is coming from the bottom front of the engine, it could also be the front main seal. Our N55 engines are run at a vacuum inside the engine. When you remove the oil filler cap, you are actually pressurising the inside of the engine to atmospheric pressure. Could be air leaking past the front main seal while under vacuum.
Run the engine with and without the belt. If the noise is there without the belt, you know it is not the A/C compressor. Last edited by MightyMouseTech; 04-13-2018 at 09:08 AM.. |
BimmerAg425.00 |
04-14-2018, 12:27 PM | #20 |
Rep 264
If the noise goes away when you remove the cap then it is most likely the valve cover. When the vent valve goes bad it can create excess vacuum in the engine, which in turn causes air to leak in through the front or rear main seal.
The proper way to diagnose would be to check the crankcase vacuum w/ a gauge via a special oil cap tool Bmw makes that has a fitting for a gauge. That’s kind of unecessary since it’s kind of obvious. Is the cap hard to get off with the engine running when the noise is happening? |
MightyMouseTech4337.50 |
04-16-2018, 08:53 AM | #21 | |||
Rep 28
