03-27-2018, 11:41 AM | #1 |
Rep 3,722
Traction control kicking in w/DSC off (LSD people chime in too)
After some snow-storm hooning and a some recent tuning sessions I've come to the conclusion that my TC system is still kicking in pretty heavily even when DSC is fully off (yes, I long press the TC button and wait for "DSC Off" to appear).
As a couple of examples - when in the snow messing around, I found that the throttle would cut sometimes extremely heavily when sliding around. To what feels like 10% of actual input (100% pedal input aka send it lol). When running some logs the other day I ran it through 3rd gear and felt some pretty substantial dips in 3rd gear, again with DSC totally off. This isn't a little "hey, minor slippage there pal, let's keep it neat" kind of feeling, it's more like, "JFC WE NEED TO CUT POWER OR YOU'RE GOING TO DIE". Which I don't want when I turn DSC off all the way... Any thoughts? Is this normal? Anyone with an aftermarket LSD that coded out the e-diff, have you seen reductions in this behavior?
"Tobias" 2013 135i ///M-Sport 6MT • Pure Stage 1 • XDI 35 HPFP • 404whp/440wtq |
03-27-2018, 01:01 PM | #2 |
Loves me some MHD!
1858
Rep 1,719
IIRC, putting it in TIM YOYO mode won't disable the E-LSD. Beyond that I seem to recall others having logged data indicating more intrusive behavior than just the E-LSD would offer.
Check that driving nannies post- I suspect it's a decent place to find points of reference on both the problem(s) and resolution. It's up to you if you want to go to the point of coding off the nannies when your not tracking the car...
1and1
135i - E82.N54 2009 BSM - MHD / xHP / DCI, PR CP & 7.5" Race IC / N55 mid & Borla . . WL RSFI, Koni, Eibach & Dinan CP's, M3 CA's / EBC Red's & Firehawk 500's X1 - E84.N20 2013 MGM - JB4 - The Wife's, now with new turbo & ewg |
elitesales305383.00 |
03-27-2018, 01:06 PM | #3 | |
Rep 3,722
03-27-2018, 01:40 PM | #4 |
C2H5OH
3915
Rep 2,144
E-Diff does not cut throttle, ever. If you are getting throttle cut it's one of 2 things, DSC interacting or a problem in the tune ... throttle cut is a TQ Reduction action. Could come from a request to protect the trans (overheat, over-rev) or an overboost condition.
If you're riding the brakes while this happens, that's the problem. There is something about brake plausibility that will cut throttle after a few seconds if both are pressed. I just looked through the tune and I didn't see it, so it must have been on the coding side I removed mine. I have a diff and coded out most of the stuff. My car does what I tell it to do. Haven't seen anything that I didn't want or expect. If you post a log maybe I can spot something? |
03-27-2018, 02:05 PM | #5 | |
Rep 3,722
The only log I have on hand isn't going to be very useful so I'll see if I can get another. I've attached one for you anyway if you'd like to take a look.
03-27-2018, 04:36 PM | #6 |
Rep 970
Drives: 2018 M2
What iminhell1 said. The ELSD shouldnt ever cut power
03-27-2018, 08:25 PM | #7 |
C2H5OH
3915
Rep 2,144
I have to amend what I said earlier.
I have had throttle cut. I was on ice and wound it up through 3rd gear. Front wheels didn't move one bit, car was actually stuck. DSC, ABS (orange brake light) and I think half engine all popped at once. But that's the only way I've got anything to act up. |
03-27-2018, 08:31 PM | #8 |
Sideways and Smiling
3027
Rep 2,860
Drives: In Exuberance
There is a thing that will reduce engine power (FLR) to prevent brake overheating. It could be, but is unlikely to be, the thing you're experiencing.
desertman123 re-pointed-out this page to me when I was doing some coding: http://www.onelapx1.com/blog/how-to-...w-actually-fun Do your logs show power cuts? If not, then it could simply be the eDiff working (not true torque vectoring) by braking the wheels...
2012 BMW 328i 6-Speed Wagon | Deep Sea Blue with Grey Dakota Leather | Manual Swap, 330i Intake + Tune, 3.15 Helical LSD, Öhlins R&T
(SOLD) 2009 BMW 128i 6-Speed Coupé | Monaco Blue with Black Sensatec | chris_flies' 128i thread |
03-28-2018, 06:22 PM | #10 |
Rep 3,722
Lol well I'm keeping it for the foreseeable future now so eff it!
03-28-2018, 07:14 PM | #11 |
1Addict
3234
Rep 7,894
Not sure. I've noticed it too on occasion but I think mine are post shift timing flatlining.
Temp redline when wheels popped free? I've had that happen to me on bad surfaces and power will cut to save the block.
01-26-2019, 05:10 AM | #12 |
Rep 98
Holy F i just tried to huck doughnuts in 2nd gear, popped the clutch full lock and the inside tire lit up for half a second, then throttle cut to like 10% as said above. I have brake fade compensation coded out and the elsd coded off. I basically followed that guys X1 post. Also had DTC long pressed “Fully off”. What gives🤷🏻*♂️
01-26-2019, 12:59 PM | #13 | |
C2H5OH
3915
Rep 2,144
I think it has to do with a wheel speed differential somewhere along the lines. If you're on ice, try chocking the front tires and slowly increase speed of the rears until it cuts throttle. My guess is that it will. And I see no issue with it as it's a protection that no one should really reach unless the fronts are not moving. Seriously is no need to do 100mph standing burnouts, when 85mph will do just fine. And I really see zero reason to code the e-diff out, ever. If you don't have a mechanical one, you just made traction worse. If you have a mechanical, you just made it even better. |
01-26-2019, 01:52 PM | #14 | ||
3027
Rep 2,860
I grenaded the open (metal) diff on my R/C truck doing donuts with one wheel spinning. Likely the combination of extremely high speed and extremely high temperature caused it's unscheduled disassembly. It works the same as the diffs on our cars (I've disassembled both), so it's a relatively scale representation. EDIT: Broken135i Please tell me you disabled the e-diff because you have a proper LSD...otherwise it's just pointless
01-26-2019, 02:32 PM | #15 |
C2H5OH
3915
Rep 2,144
chris_flies
Keep in mind this is not our diff or fluid but, |
chris_flies3027.00 Matticus913474.50 |
01-26-2019, 02:37 PM | #16 |
3027
Rep 2,860
Gale Banks is awesome! Very intelligent guy that can explain things well to mere mortals such as myself. I'll need to watch this vid later...
Tags |
control, dsc, e-diff, lsd, traction |
