03-20-2018, 08:34 PM | #1 |
Rep 63
Adaptive lights, Seat Slide back and
the GTS ECU flash have been done to my F82. The *seat slide* back function was working fine until the GTS flash. Adaptive headlights work fine, : GTS shift is awesome , flashing bake lights work, just not the seat slide back. Does anyone know if there is a relation it is what the possible reason can be? Point me in the right direction?
Thanks guys, |
03-21-2018, 12:52 AM | #2 |
Rep 8,364
GTS ECU flash is transmission (EGS).
Easy Entry is FDL Coding (FRM, SM) Adaptive Headlights (FRM, KAFAS, FLE or LHM) I am not seeing the correlation. |
03-21-2018, 09:55 PM | #4 |
Rep 8,364
03-22-2018, 05:43 PM | #5 | |
Rep 63
It has been working on and off over the last days. Today it didn't work, yesterday it worked 2 out of 3 times. Last edited by Racing Instructor; 03-22-2018 at 05:54 PM.. |
03-22-2018, 08:17 PM | #6 |
Rep 50
Drives: 2015 M3 MG/BK
Are you manually changing the seat position at all? I believe this only moves to/from one of the two saved positions only. If it doesn’t start at a saved position it won’t move back. Once back if you change the seat position manually it doesn’t move forward to saved position.
You aren’t switching key fobs by chance are you? Under the Doors/Keys in iDrive there is the Last seat position option that I believe gets saved to the profile of each key. |
03-22-2018, 08:34 PM | #7 | ||
Rep 63
Thanks Icyman077, I'll report back here tomorrow. |
03-22-2018, 11:23 PM | #8 | |
Rep 8,364
03-23-2018, 11:20 AM | #9 | |
Rep 63
"remember last setting" in iDrive setting is turned off. Still not working today |
Nick770087.50 |
03-23-2018, 12:48 PM | #10 |
just a fool
345
Rep 675
It is probably the coded moving distance exceeds the allowable travel distance from your starting position. Move the seat forward, and see whether that solves the problem. There is a dedicated code thread that discusses how to determine the appropriate coding parameters. Search it up.
03-23-2018, 03:30 PM | #11 | |
Rep 63
Still not working......... |
