03-04-2018, 04:17 PM | #1 |
Rep 132
Still can’t figure it out - stumble/irratic idle
I have owned my 128 since 2010, has 62000 miles. I replaced the plugs at 40k. I have never had an engine light.
Issue/symptoms: After a few minutes of driving SOMETIMES when I am stopped with car in gear and foot on the brake the tach drops a tad and it feels like the engine is stumbling. It always clears up after about 2-5 secs or I start to accelerate. Other times it will skip or stumble when coming off idle and LIGHT throttle. Just a miss or 2. Engine light never comes on. I checked the INPA software and everything is normal. I checked the cam sensor and no oil in the connector. It’s hard to diagnose when it’s so quick and never throws an engine light or pending code. Car always starts 100% fine and idles fine until you drive for a few minutes. Ideas? I been trying to figure this out for years and waiting for something to fail so I can replace it. Still waiting! |
03-04-2018, 04:32 PM | #2 |
European Editor
10589
Rep 22,992
My first thought was a bad coil pack. Until you mentioned that sometimes it happens when your foot is on the brake pedal. To me I am thinking your vacuum check valve for the brake booster might not be working properly.
On the 128i they have a mechanically driven vacuum pump. But there should be a check valve somewhere in the piping. Maybe hose #8 ? I really can't tell in the ETK. http://www.realoem.com/bmw/enUS/show...diagId=34_1556 You might also have your dealer run your VIN... I know these vacuum pumps do go bad and have had some recalls on them. Its worth checking for any open recalls. IF you have access to a code reader... I would also look at long term fuel trims to see IF you have a vacuum leak. A bad brake booster vacuum valve could cause that. Also... when you replaced the spark plugs... did you use BMW dealer bought plugs? Some people have had issues like a weird idle or misfires with aftermarket plugs. IF your car has more than 80K miles... you should consider replacing all six coil packs too. Dackel
03-04-2018, 04:45 PM | #3 |
Rep 132
I did use NGK plugs that seem to be to OEM equivalents. I can check INPA to see what the fuel trims are. I don’t believe this is the problem only because it’s so intermittent, some days all is fine. I was hoping coils but no silver bullet. I don’t want to just throw 6 coils at it and have no change. I would figure coils or plugs would throw a CEL
03-05-2018, 02:24 PM | #5 |
Former Opel GT Pilot
327
Rep 771
I have had similar symptoms from bad gasoline. Do you use top tier fuels?
So, that's it. I am doomed. There is no patch, no methadone, no substitute. Curse you BMW. Curse you and your seamless power delivery. Curse the incredible sense of road feel. Curse the comfort, the luxury, the envious looks from the masses. I am... hopelessly addicted.
03-05-2018, 06:38 PM | #8 |
Rep 3,071
91 from Shell/Chevron
OR 91 from 7-11 or Stop-N-Go?
2011 135i w/ DCT | ZSP Sport Pkg | PPK | Ohlins R
03-06-2018, 09:27 AM | #10 |
Sideways and Smiling
3027
Rep 2,860
Drives: In Exuberance
Try putting a bottle of Techron injector cleaner into a quarter tank of gas before refilling. It seems to be the cure-all for rough idles or "stumbles."
Costco's gas supplier is Top Tier. I go there as much as possible, it's about $.40 less expensive (I'm tuned, I have to run 93) than everything else, and better than a good portion of all else...
2012 BMW 328i 6-Speed Wagon | Deep Sea Blue with Grey Dakota Leather | Manual Swap, 330i Intake + Tune, 3.15 Helical LSD, Öhlins R&T
(SOLD) 2009 BMW 128i 6-Speed Coupé | Monaco Blue with Black Sensatec | chris_flies' 128i thread |
03-06-2018, 11:28 AM | #14 | |
Rep 638
yeah exactly what dack is saying on the plugs, but' you'd throw codes for a bad coil pack
Dackelone10588.50 |
03-06-2018, 11:31 AM | #15 |
Rep 132
I did use the oem NGks. I just ordered another set , it’s been 20k miles. I am also replacing all the coils. Figure I give it a try for $170. Maybe one is acting up, idk but it’s gett more often but can’t wait any longer for a code in INPA
Dackelone10588.50 |
03-06-2018, 03:12 PM | #16 |
Rep 132
I just pulled the plugs and all looks well to me. Stuck my Wi-Fi iPhone boroscope in the cylinders and a small amount of carbon but all looks normal
Captain Blood13871.00 |
03-06-2018, 03:16 PM | #17 | |
Rep 6,196
When I accidentally installed the N54 plugs in my N55, I was getting terrible misfires. Never showed any codes. Edit: The ONLY place you can get OE plugs is at the dealer. |
03-06-2018, 03:19 PM | #18 |
Rep 132
MightyMouseTech4337.50 |
03-06-2018, 04:11 PM | #19 |
European Editor
10589
Rep 22,992
^^Yep. But most people don't learn their lesson chasing after a erratic misfire on these cars. Their IS a difference between OE and OEM. But most don't know the difference like we do.
OP - go buy some plugs from any BMW dealer. Make sure they say "BMW Bosch" on them. There is a design difference(in the ceramic insulator) on the OEM aftermarket plugs(vs the BMW(OE) ones. Dackel
jaye9441014.00 |
03-06-2018, 04:15 PM | #20 |
European Editor
10589
Rep 22,992
Nope. Well... kind of. BMW used NGK's and BOSCH plugs. But I bet the plugs bought from a BMW dealer are different to the aftermarket(OEM) versions.
http://www.realoem.com/bmw/enUS/show...diagId=12_1417 03 Spark plug, High Power NGK PLZFR6A11S 6 08/2009 12120035915 $21.32 ENDED 03 Spark plug, High Power 6 12/2009 12122158253 03 Spark plug, High Power BOSCH FR7NPP332 6 08/2009 12120032138 $21.32 ENDED 03 Spark plug, High Power 6 12/2009 12122158253
03-06-2018, 04:41 PM | #21 |
Rep 132
My car came with NGK plugs. The BMW plugs ARE exactly the same, same part number from NGK. The plugs being incorrect are not the problem. They were fine for many years. Maybe one is going bad or a coil is acting up but I won’t know until I swap everything to new the end of the week. I suspect there is something else going on and I can’t solve it because nothing in the computer shows an issue
03-07-2018, 01:17 AM | #22 |
Rep 90
My '11 128 is doing the same thing. It's very subtle (nobody notices but me) and it's only once in a while. If i'm at a stop light it might very subtly "hiccup" really quick. I did change my plugs with BMW OEM's about 6 months ago. I also changed the coil packs with the "high performance" red ones from BavAuto (apparently "high performance" is BavAuto speak for "chinese made crap"....I digress...) I'm going to try the fuel additive and see if that helps, but i'll be following this thread nontheless
jaye9441014.00 |
