09-10-2018, 08:05 PM | #3 |
Rep 1,092
Drives: F82 M4 CP
What OBD dongle is everyone using? I've been looking at the Vgate iCar Pro Bluetooth 4.0.
https://www.amazon.com.au/Vgate-Blue...+Bluetooth+4.0 Also, can the GTS code changes be done through Bimmercode or is specialised coding required?
2017 BMW M4 Competition - Mineral Grey
2009 BMW 135i - Titan Silver - SOLD |
09-10-2018, 09:59 PM | #5 |
Rep 1,092
Drives: F82 M4 CP
What does Easy Entry do?
09-10-2018, 10:17 PM | #6 |
Rep 1,973
09-10-2018, 10:41 PM | #7 | |
Rep 1,092
Drives: F82 M4 CP
What other advanced options are people doing?
09-10-2018, 11:08 PM | #8 | |
Rep 1,973
Makes getting in and out much easier |
09-11-2018, 12:29 AM | #9 |
Rep 1,092
Drives: F82 M4 CP
Thanks domino_z . Have you had many issues with error codes? Do you usually get them with basic coding or is it a matter of happening when you make a mistake in doing the code changes?
10-17-2018, 06:56 PM | #10 |
Rep 1,092
Drives: F82 M4 CP
My dongle just arrived so I'll get to coding in the coming days.
I'll be changing: * Legal disclaimer remove * Auto start/stop remember last selection * Door lights on when reversing * Heated seat temperatures down 5C across the board * Mirrors fold on CA locking (delay to zero)
10-17-2018, 09:40 PM | #11 | |
Rep 185
Other coding options to consider , rear camera zoom , audible chirp on lock / unlock |
10-17-2018, 09:42 PM | #12 | |
Rep 1,092
Drives: F82 M4 CP
The car already reads messages to me while the car is moving, so I'm happy with that for the moment. What advantage does the zoomed rear view provide? I only ever use the top down view anyway, so it may not be a benefit to me. The chirping makes sense although the car makes a decent "chunk" noise when locking, so it may be something I turn on and switch off later (plus I go to work early most days and I don't want to wake up the house with beep beeps).
10-17-2018, 10:44 PM | #13 | |
Rep 178
Thought I'd ask before ordering an OBD adapter for my iPhone. Cheers, Ed
2016 Mineral Grey LCI F80 ///M3 Competition Pack M-DCT Sedan - Evolve Technik Stage 2 | BMC Air Filters | Akrapovic Downpipes | KW HAS Kit | M Performance Front Lip & Carbon Splitters | M Performance Side Skirts | M Performance Rear Diffuser | M Performance Boot Spoiler | M Performance V1 Steering Wheel | M Performance Carbon Shifter & Hand Brake | M Performance Pedals | iND Reflector Deletes | Pomponazzi Coating
10-18-2018, 01:57 AM | #14 | |
Rep 1,092
Drives: F82 M4 CP
When you go to buy your OBD dongle, Amazon Australia has them at comparable prices to elsewhere. Mine was just under $40 and arrived in two days.
10-18-2018, 05:10 PM | #15 | |
Rep 1,092
Drives: F82 M4 CP
Well, all I can say is that my fears were completely unfounded. The hardest part was getting the phone to pair with the dongle. After that, it's pretty darn simple. Just go through the modules you want to alter and select the changes. Then hit code and the app does its magic. A fair whirs and groans later, the ECU restarts, a couple error messages pop up on the screen (which are easily cleared via the app if you are on Android - you need a separate app on iOS) and the car is ready to go. One suggestion I will make is to write a list and which module they are under. You can do this by having a practice run in the Demo mode of the app. The list will help you breeze through without having to faff about finding things. The only issue I had, and this has been well documented so wasn't a surprise, is that you lose your radio presets and equaliser settings. Putting the eight presets back in took about two minutes as I knew exactly what went where, and I had taken a photo of my equaliser settings a little while back when playing with the sound, so that won't take more than five minutes to put back in place. Overall everything went as planned and I left for work bang on time. The changes have stuck and the car is as I would like it to have been from factory.
10-18-2018, 08:27 PM | #16 | |
Rep 178
